@kromar I agree with you, more work could be done in this area. Making collections the children of objects would be very difficult because collections are containers for objects, not the other way around. I’m not saying it couldn’t be done, but it’s a very large task that wouldn’t be a good fit for the summer of code.
On that topic, @kynu I agree, a grouped mesh that could support instancing and modifiers would be amazing. I even talked about this with @billrey the other day. Very off topic though, so let’s try to stay more on topic here.
@tintwotin I’ve noted some smaller things that could be done this summer (like drag and drop). Those mockups you have made are great, but I really think that it would be better to make a separate design task for the sequencer workflow.
@Oskar I see the problem. One issue is currently Blender doesn’t allow selection of hidden objects. You can “outliner” select it, but the actual object data is not selected. The Select Hierarchy
operator is selecting objects recursively, so when it gets to Sphere.001 in your example it cannot select it. Now that selection syncing works well, a better solution for this operator would be to select the objects recursively with Outliner selection, that way it still syncs to visible objects, but the whole tree is selected for drag+drop. Most of the context menu operators in the outliner will get some fixes this summer.
An alternative would be to drag children with parents when linking between collections.
@LeoSch I hope to make arrow key renaming better in the next few days. The workflow would be Up/Down then F2 to rename. The rename field is a generic UI rename field, so I’m not sure if it could be mapped to Up/Down to rename the next item. That would be great though, so I’ll keep that in mind.
We use lots of modifier keys for drag+drop currently, so I don’t think duplicate would be able to fit well there. For your last point, collection instances!
@Rayfly0225 cool video, but there aren’t any links to your addon so others can benefit!
@dan2 Parent highlighting when active is in a collapsed hierarchy. I really love the idea. and I wanted to do it last summer, we already have 3+ types of highlights in the outliner so this would need to be done right to not add more clutter.
