Blender UI paper cuts
Does it bug anyone else that File menu operations cannot be invoked using the Shift-R ( Repeat Last Operation ) command?
This is especially cumbersome when appending or importing assets. Having to go through the File menu + sub menus repeatedly is annoying.
I realize that these operations can be added to the Quick Favorites menu, which helps a tonne, but isn’t this an inconsistency?
A very common convention from other 3d packages would be to move the current frame number field which is way over there on the right (and has < > buttons that you can use for next/prev frame, it’s just not intuitive the way the rest of the transport controls are) and put it between the play buttons (without its own < > buttons) so that the current frame number that the transport controls are affecting is right there.
this tool should be unique …
at the moment as it is, it creates confusion …
if we are in vertex select and click on the edge slide tool, it does not work, and vice versa for edge select and vertex slide does not work
it makes no sense that it is split into two tools.
if we are in edge mode, it should work for the edges …
if we are in vertex mode, it should work for the vertices …
that’s all.
Screenshot%20(3)
Knife tool doesnt have undo function. When you accidently place a vertex in the wrong spot you have to start all over again.
That would probably be easy to do but not so elegant. You don’t always have the sidebar open - I think it should be right there in the header next to the ID selector.
I have always pressed esc to cancel the function …
it’s also true that if you cut out a fairly complex shape, it’s a nice headache to reset everything for a wrong vertex …
This makes sense to me. @jendrzych What do you say? The keyframe doesn’t have to have a color obviously, but this would clarify the fact that it jumps to the next key.
Maybe something more condensed like this ?
NextPrevKeyframeMock01
Those don’t act the same at all depending on your selection.
About that thing with the region borders getting in the way of navigation - can’t we simply end the regions where their content ends ?
Just put an alpha transparent ‘outline’ in middle of the arrow and the key and it’ll be a real winner, IMO. Currently they melt together into a single shape.
Right Clicking and Joining Mesh is very easy, but once joined it is a lot more tricky to separate them again.Can we add separate too right click please.
Here it this modded with a transparent outline in the middle.
NextPrevKeyframeMock01Outlinetransp04c
methinks the arrow should be over the keyframe, no? Also, it’s missing frame stepping.
This would be hard since Linux doesn’t have a standard GUI. It might involve looking up the window manager at use in the current display, and I’m not very sure there’s a standard way of gathering this information reliably. Also supporting each available WM conventions, and keeping up with them, seems like too much work for not so much return. Supporting just the mainstream ones (say gnome/KDE) might not be fair enough. Showing the standard OS/WM dialogs breaks the whole theme feel.
I do like the idea. Everybody likes a standardized workflow and a popup with buttons in the wrong order than usual can screw things if one is fast enough to click. I just personally think accommodating to the OS/WM ways and maintaining might involve too much work not worth the return, and showing standard dialogs is ugly.
I think Blender interface is already specialized enough that users may expect dialogs not to fit their OS/WM way.
Another UI paper Cuts for me. What do you think…?
The keyboard shortcut is not synchronized with the icons. Also in edit mode.
21 posts were split to a new topic: Tool shortcut keys
(repost because it was accidentally posted as a reply to an unrelated comment)
When animating in stepped and using autokey animators often scrub with the mouse to quickly look at poses. In order to actually change a pose, they need to be directly on it otherwise a new frame is created.
Could we get a button that enables Snap-scrubbing?
I wrote a little python script, it should be fairly easy to implement. It only needs to be connected to a button. It detects if you’re moving to higher or lower numbers and according to that snaps next or previous.
bl_info = {
    "name": "ScrubSnapper",
    "author": "Karlo Pavicic Ravlic",
    "version": (1, 0),
    "blender": (2, 80, 0),
    "location": "View3D> N > Handy Anim Tools",
    "description": "Snap frame to nearest keyframe in drag direction",
import bpy
from bpy.utils import register_class, unregister_class
from bpy.props import BoolProperty, EnumProperty
from bpy.types import Panel, Menu
from rna_prop_ui import PropertyPanel
CurrentFrame = 0
def frame_handler(scene):
    global CurrentFrame
    if not scene.asset_manager.snapscrub:
        return
    if CurrentFrame > scene.frame_current:
        bpy.ops.screen.keyframe_jump(next=False)
    if CurrentFrame < scene.frame_current:
    if CurrentFrame == 0:
        CurrentFrame = scene.frame_current
#Booleas
class PropertyGroup(bpy.types.PropertyGroup):
    snapscrub: bpy.props.BoolProperty(
        name='SnapScrub',
        description='Snap to frames while scrubbing on the timeline')
# Draw the control panel
class HATOOLS_PT_ButtonPanel(bpy.types.Panel):
    """Panel Creation"""
    bl_label = "Handy Anim Tools"
    bl_idname = "object.hatoolss_pt_handytoolspanel"
    bl_space_type = 'DOPESHEET_EDITOR'
    bl_region_type = 'UI'
    bl_category = "Handy Anim Tools"
    def draw(self, context):
        layout = self.layout
        view = context.space_data
        scene = context.scene
        wm = context.window_manager
        manager = context.scene.asset_manager
        activeArmature = bpy.context.active_object
        # Display menu if armature belongs to MSW
        row = layout.row()
        row.prop(manager, "snapscrub", text="SnapScrub", toggle=True)
classes = (
    HATOOLS_PT_ButtonPanel,
    PropertyGroup,
register, unregister = bpy.utils.register_classes_factory(classes)
#Register booleans
def register():
    for i in classes:
        register_class(i)
    # storing property in scene for this example
    bpy.types.Scene.asset_manager = bpy.props.PointerProperty(type=PropertyGroup)
def unregister():
    for i in classes:
        unregister_class(i)
if __name__ == "__main__":
    register()
try:
	bpy.app.handlers.frame_change_pre.remove(frame_handler)
except:
	pass
bpy.app.handlers.frame_change_pre.clear()
bpy.app.handlers.frame_change_pre.append(frame_handler)
scrub_demo2
I hope my script can help.
That’s probably not just a UI papercut, but I second the idea. Mad props for writing it yourself. I proposed a little something on the same topic a while ago : https://blender.community/c/rightclickselect/P0bbbc/
Just to add to this: the modifiers could do better with a description. The motion tracking constraints are missing one too.
Thanks!
I’ve updated the code to have a button in the dope sheet and uploaded a better gif. Copy-paste it, run it, and it should work.
