There is a little Papercut at the Addon measureit. When disabeling “atomatic position” it would be nice, when all values would be set to 0.00.
This would save much time while creating technical drawings.
In the NLA editor, there is no way to change that blue color for the object’s channel.
Kind of petty but it bugs me because I can’t fully harmonize my theme.
A question - is there way to turn on all collections to view entire scene and switch back to configured state with a single hotkey?
Didn’t found it.
If you have 1000 collections and you want to see entire scene to manage in current View layer - you are in trouble.
That’s actually was the point - to view all collections in current visibility layer.
For example, I have 500 visible collections with houses and 500 invisible with entourage.
But windows, fences, doors, roofs and other stuff collection are turned off.
So I need to have 600 turned on, and 400 tured off.
How is it supposes to locate those 100, keeping at the end visibility of other collections intouched?
By creating and deleting 100 visibilities states, remembering name, going 100 times to regular visibility state and setting visibilitties to those collections?
Or, maybe, clicking throug 500 turned off collections manually, remembering where you have been and what you’ve seen?
So there is sheep model in collection “Car”, BMW model in collection “1111”, and roof with grass shares same collection, because deadline was yesterday when file were created.
Seriously, the collections system is definitely good. But it requires serious improvements. I think she conflicts with groups. It is also not very convenient to create surjective collections (when the same object is in several collections at once).
@AUDITORIUM
I think you should make your comments clear and simple … do not make sarcastic jokes or anything, your English is not good and you confuse people.
There are also E / Alt+E and H / Alt+H shortcuts in outliner, that controls collection visibility, but the only way to get previous state is undo.
So, they are just for looking, not managing, as far as everything you can do viewing everything will be canceled.
As it was told in Layer Maniphest - complex layer systems usually have separate undo engine.
It seems, collections were designed like they will have some limit.
There are so much things now to think about…
I mean, they were designed like there will be 20-50 of them, otherwise they comes to mess.
As you can remember, from maniphest, in AutoCAD we have a deal with 4k - 8k layers per file, because it have tools for supporting that amount of layers.
Current Blender collection management supposes there are not more than 50 of them.
If you will have at least 100, you will get tired during sorting before even to start to work.
Again, you can have as many view layers as you want, and so you can store as many visibility sets as you would like.
Of course, but there are no tools to make even single proper visibility setup for file with thousant collections.
