There was a thread started almost a year ago. A lot of people were very interested in this… sadly, the developer has gone silent since then. Check out the thread
I wonder if we could make “Lock Camera to View” (which is really “Lock Camera to Camera View”) the default? This makes positioning the camera very intuitive for new users and I think it’s the default behavior one would expect when switching to Camera View.
Without it, new users often get frustrated trying to figure out how to get the camera framed up the way that they want. Having to bring up N properties and find this obscure option before the camera actually moves when you navigate in the Camera View seems just a bit too much.
Thoughts?
That option really needs to get out of the N panel. Unbelievable.
Does it really? All the viewport related camera settings are in the N panel already. While it’s true that that option is about the actual Camera object, it’s still somewhat viewport related, since you’re controlling the camera with the viewport, essentially.
Everything related to the viewport camera manipulation should be in the view menu like in any other 3d software.
This splitting of settings is what makes blender be a tough app to learn. Long time blender users may think this is ok, but it’s not. And not only that, there are settings in the preferences that should be in the view menu also.
It’s sad.
Automatic reloading/refreshing all textures
Oh, my god yes!
I’ve been meaning to suggest this for a while now, but it deserves its own thread.
Also because I think that both bevel weights and crease weights should have a similar color coding!
(The way 2.8 still draws a black center line, with cyan “glow” on both sides of the line is very harsh on the eyes.)
UPDATE: Holy shit! Papercut was already fixed in the latest beta… amazing! I still think the black line in the center gets a little bit in the way of readability, though…
EDIT: With this, I’m also hoping that there’s a key I haven’t found to goggle overlays on and off. When I search the Keymap for “overlay” it comes up empty.
This one took a little digging into the documentation.
put it under 3D View -> 3D View (Global)
wm.context_toggle
space_data.overlay.show_overlays
I wanted to say that Multi Select Loops should be in a Select > Select Loops menu, but now I realized that Edge Loops command does the same thing? Is there a reason to even have Multi Select Loop?
The answer is in the question. No.
Wow, thank you for the workaround! It worked great.
The papercut is still definitely that “overlay” should be a searchable word for that setting.
Shift Alt Z is the default I think
Thank you for pointing that out! But… why the heck is it named “Context Toggle” instead of “Overlay Toggle”?
Also, I just remapped it to the key under Esc (§ on my Swedish keyboard although Blender thinks it’s \ and doesn’t understand åäö I just noticed)… who the heck wants to reach for three keys for something that you might do several times a minute while modeling?
Still a papercut that has room for improbement, imo.
Imho the default focus for the (text)cursor in the ‘Save’ and ‘Save As’ dialog should be in the filename field. You should be able to hit Ctrl+S, or Shift+Ctrl+S and start typing the desired filename + press enter to save. Currently keystrokes end up nowhere.
Yes, I too would like to just type the name and hit enter most of the time.
Actually there are quite a few keybinds for the File Browser. I often wish keystrokes went nowhere after looking up from typing a long filename and realizing I have no idea what I just told the file browser to do to my system.
I think it would be nice if the focus was always on the filename field and all the keybinds would involve modifier keys so they could be active at the same time but not conflict with filename characters.
So many posts so this probably came up before but here’s a little one:
When I choose studio light or a matcap and click on one of them I’m just testing different looks - I don’t want the panel to disappear at that moment but only when I move away my cursor from the thumbnail list
On the contrary with transform orientations and pivot point I expect the menu to disappear after clicking
but I understand it not doing that for consistency with other popups.
Anyway shading thumbnails should behave the same way imho
Show overlays already has a shortcut - it’s somewhere on the Z menu iirc. Context toggle is just the generic name of a command that toggles something within the current context, take it as the “shortcut type”.
@kynu I like your idea, the matcap list could a popover.
not if want to remove the nav icons
I get what you mean, I think the best option would be to have more control about what text is being displayed because at the current state you’ve either an option to show/hide all textual information along with the object name (which is still an option and I’m really glad that devs have made it possible) or show everything (which is admittedly not much at the current state). On the other hand I see many people complaining about not being able to see vertices/faces/edges count in the main view (this information is put on the right bottom corner), there exists a plugin with a similar functionality but IMHO it is too much of a hassle (I really do exaggerate here, because installing plugins is not that hard in blender but still) in a software that has modeling as one of its main features. The tricky part here besides the development time needed to implement it, how can it be incorporated into overlays popup, which is already filled with so many options.
