17 February 2025
17 February 2025
Announcements
Modules & Projects
Project Setup
  • Design task: #133001
  • Solidified designs enough to start work on the first milestone, “Blender Variables”.
New Features and Changes
Compositor
  • Use gpu::TexturePool instead of DRW pool (commit) - (Omar Emara)
Cycles
  • Add Blackwell to Cycles CUDA binaries architectures (commit) - (Patrick Mours)
  • Change the integration measure in Huang Hair from gamma to h (commit) - (Weizhen Huang)
  • oneAPI: Enable kernels compression (commit) - (Xavier Hallade)
  • oneAPI: Optimize texture access by using GPU HW sampler (commit) - (Nikita Sirgienko)
GPU
  • TexturePool: Add texture pool functionality to the GPU module (commit) - (ClĂ©ment Foucault)
Geometry Nodes
  • CSV import node (commit) - (Devashish Lal)
  • Remove extra copy step in CSV import node (commit) - (Hans Goudey)
Mesh
  • Optimize vertex to edge attribute domain interpolation (commit) - (Hans Goudey)
NDOF
  • Rework input handling on macOS (commit) - (kgalik)
Object
  • Prevent unnecessary depsgraph tags for no-op materials resize (commit) - (Hans Goudey)
Overlay
  • Move 3D cursor drawing to the overlay engine (commit) - (ClĂ©ment Foucault)
Point Cloud
  • Expose 3D Cursor, annotation and ruler tools (commit) - (Dalai Felinto)
  • Select All/None/Invert (commit) - (Dalai Felinto)
  • Implement “Affect only Origins” object transform option (commit) - (Hans Goudey)
  • Implement “Set Attribute” operator (commit) - (Hans Goudey)
  • Implement box, circle, lasso select tools (commit) - (Hans Goudey)
  • Implement transform operator (commit) - (Hans Goudey)
Sculpt
  • Improve node tools performance for simpler changes (commit) - (Hans Goudey)
  • Reduce overhead for multires index buffer creation (commit) - (Hans Goudey)
Sequencer
  • Move 2D cursor drawing from DRW to sequencer using IMM API (commit) - (ClĂ©ment Foucault)
Shader
  • Expose light path “is volume scatter ray” in UI (commit) - (Alaska)
UI
  • Remember scroll offset for tree-views (commit) - (Julian Eisel)
  • Improve save report message (commit) - (IREXTIA)
  • Disabled Message Before Python in Tooltips (commit) - (Harley Acheson)
  • Decrease Alert Dialog Icon Size (commit) - (Harley Acheson)
  • Themeable RedAlert, Error, Warning, Info Colors (commit) - (Harley Acheson)
  • Status Bar During Text and Numerical Entry (commit) - (Harley Acheson)
  • New Presets Icons (commit) - (Harley Acheson)
  • Tightened Status Bar Spacing (commit) - (Harley Acheson)
USD Importer
  • Add default Plane shape to USD Importer (commit) - (Maxime-Cots)
VSE
  • Over Drop effect was not doing anything useful, map it to Alpha Over (commit) - (Aras Pranckevicius)
Weekly Reports
