10 July 2023
Modules & Projects
- 2023-07-04 VFX & Video
- 2023-07-06 Pipeline, Assets & I/O Meeting
- 2023-07-10 Eevee/Viewport Module Meeting
- 2023-07-10 Grease Pencil Module Meeting
New Features and Changes
User Interface
- Gray out shape key list entry on mute (commit) (rBrenick)
- Improve 3D text selection (commit) (Guillermo Venegas)
- Improve region resize edge detection for transparent regions (commit) (Julian Eisel)
- Draw hierarchy lines for tree-views (commit) (Julian Eisel)
- Improve how region size snapping respects the maximum size (commit) (Julian Eisel)
- UV Editor
- Add “Invert Pins” to the menu (commit) (Chris Blackbourn)
EEVEE & Viewport
- EEVEE Next
- EEVEE
- Change sun light factor to match Cycles (commit) (Weizhen Huang)
Animation
- Improve drawing of locked FCurves (commit) (Christoph Lendenfeld)
- Set hardmin/max for frame start and end of action (commit) (Pratik Borhade)
- Allow setting the graph editor slider unit and mode (commit) (Christoph Lendenfeld)
Cycles
- Change sun lamp to have uniform intensity at high angles (commit) (Lukas Stockner)
- Replace spot light disk sampling with sphere sampling (commit) (Weizhen Huang)
- Add texture to sun light (commit) (Weizhen Huang)
- Remove Point Density Texture support for surfaces (commit) (Brecht Van Lommel)
- Avoid printing capabilities when there are no devices (commit) (Nikita Sirgienko)
- Improve oneAPI requirements text in the UI (commit) (Xavier Hallade)
- Make use of maximum concurrent compilations on Metal (commit) (Michael Jones)
Geometry Nodes
- Fill new quad poly offsets in parallel (commit) (Hans Goudey)
Grease Pencil V3
- API tweaks to prepare for drag & drop reordering (commit) (Julian Eisel)
- Select circle (commit) (Falk David)
- Add operators to insert blank frames (commit) (Falk David)
- Add separate paint mode (commit) (Falk David)
Core
- Optimize utility for index counting (commit) (Hans Goudey)
Transform
- Revert “Transform: Allow navigation by default” (commit) (Germano Cavalcante)
USD
- Improve light units conversion (commit) (Brecht Van Lommel)
Python API
- Remove unused Blender Internal properties from lights (commit) (Brecht Van Lommel)
Weekly Reports
- Amélie Fondevilla
- Bastien Montagne
- Brad Clark
- Campbell Barton
- Chris Blackbourn
- Christoph Lendenfeld
- Dalai Felinto
- Falk David
- Germano Cavalcante
- Hans Goudey
- Harley Acheson
- Jacques Lucke
- Jeroen Bakker
- Julian Eisel
- Lukas Stockner
- Miguel Pozo
- Nathan Vegdahl
- Omar Emara
- Philipp Oeser
- Pratik Borhade
- Richard AntalĂk
- Sergey Sharybin
- Sybren StĂĽvel
- Thomas Dinges
- Wu Yiming
