Some comments on the filter / options drop down:
- There seems to be a lot of “whitespace” in the top half.
I would try something like squishing all the first four options together and removing the Search header, for example:
[ ] Sync Selection
[ ] Sort Alphabetically
[ ] Case Sensitive Search
[ ] Exact Match
That ordering and the addition of the word “search” seems sufficiently descriptive and highlights Sync Selection as the most major mode setting.
What happens when “Sort Alphabetically” is off? Is it creation order, or what? There should be a tooltip that explains this (currently there’s no tooltip for this option).
The currently un-checked options in this panel are too dark. They actually appear disabled and it looks like you should not be allowed to select those search options for example. I was actually surprised to discover that across Blender selected checkbox text does actually get slightly brighter but it’s a very subtle effect that should be used here as well.
When [ ] Objects is deselected it makes sense to show the sub-options below it as “disabled” but the drastic dimming should only be used to indicate something is actually disabled and currently not applicable and potentially not enableable.
- With “Sync Selection” as well as the search options, the “filter” icon feels less and less appropriate and maybe it should really be changed to a settings “gear” icon. Having filter options in settings feels more right than putting non-filter options under “filter”.
