well as a windows user I prefer my folders to be orange.
basically your design but swapped the blue and orange.
Select Material button works right.
Try to select 3 materials in a row, if it will override.
(that is impossible)
Didnât found a discussions about new file manager.
Two questions
Is there reason to keep filename so far from itâs path? It forces to took back and forth in order to see itâs full location.
Pasting full filename path donât splits it into path and filename fields anymore.
Workflow case:
Where those ârgbâ colors in the graph editor are coming from? They are too strong , they need to be tweakable in the theme settings.
But its a WIP, hope they can change some aspects, but this is just first testing i guess
PS for me it does split filepath and filename, i justneed to press return/enter. For me its OSX
The new vertical alignment for the navigation icons looks nice âAâ but in âBâ im not sure if its right
Nice? Are you serious?
This was a bad design from the start. Now letâs enjoy the consequences.
This should be reverted asap.
lets be honest in the last two weeks there where really controversial changes that are actually a problem, vertical icons its not a problem, if the properties editor wouldnât be where it is those vertical icons would be ok.
its different but its not ugly, the thing comes into play when the properties editor its open with the tabs closed, there its no longer that nice.
In my scale of ânop doesnât workâ this rates a lower than other lot of things at the moment.
Better yet, somewhere outside the blender window.
You can switch off the Navigation Controls in Prefs if youâre used to keyboard + mouse/pen navigation:
My current top 3 Blender UI desires:
Blender Foundation actually made a public request for that position (see somewhere near end of the page)
I remember seeing Pablo doing exactly that in an old blender today video. But now it is not possible anymore⌠??
oh come on! thatâs an euhemism. B is terrible
They had a open position for a UI developer, but I think that like an programmer, not designer of UI and UX.
Oh yes. In a file Iâve worked with I think I had the problem that the graph colours were edited in a different UI color theme (very low on contrast/bad readability) which somehow carried over in the file but couldnât be replaced by switching back to the default color scheme.
I also could never find the coresponding color settings in the teme editor.
Maybe we could have somethhing like an eyedropper tool in the theme editor which scrolls directly to the corresponding color when clicking a panel in the UI?
Re-reading now, I guess youâre right
The Select Linked (L) F9 redo panel has a duplicate:
Should be:
