24 February 2025
24 February 2025
Announcements
Modules & Projects
Project Setup
  • Design task: #133001
  • Started work on implementing “Blender Variables”.
New Features and Changes
Anim
  • Update Action RNA descriptions to clarify legacy status (commit) - (Sybren A. StĂŒvel)
Brush Assets
  • Add Material to linked editable assets (commit) - (Brecht Van Lommel)
Compositor
  • Add Float4 type (commit) - (Omar Emara)
  • Reduce vector type components to 3 (commit) - (Omar Emara)
  • Support Vector outputs for Image node (commit) - (Omar Emara)
Core
  • Add warning when opening deprecated BigEndian-saved Blendfiles. (commit) - (Bastien Montagne)
Curves
  • Separate to object operator (commit) - (Hans Goudey)
  • Implement join operator (commit) - (Hans Goudey)
  • Add Split operator (commit) - (Laurynas Duburas)
Cycles
  • HIP-RT 2.5 integration and gfx12 support (commit) - (Sahar A. Kashi)
GPU
  • Add --profile-gpu (commit) - (Miguel Pozo)
Geometry Nodes
  • Make CSV parser more reliable and faster (commit) - (Jacques Lucke)
  • Improve multi-threading and avoid redundant work in CSV import (commit) - (Jacques Lucke)
  • Eagerly update bounding box after CSV import (commit) - (Jacques Lucke)
Grease Pencil
  • Make brush asset pinned materials local (commit) - (Brecht Van Lommel)
MaterialX
  • Support sheen distribution input for Microfiber/Zeltner (commit) - (Pablo Delgado KrĂ€mer)
Mesh
  • Grid-fill now supports replacing existing faces (commit) - (Jason C. Wenger)
Metal
  • Add support for packed_float3 as storage buffers (commit) - (Jeroen Bakker)
Modeling
  • Support normalization with locked vertex groups in N-panel (commit) - (Andy Beers)
Object Mode
  • Conversion no longer depends on the active object (commit) - (Campbell Barton)
Point Cloud
  • Add cached full points BVH tree (commit) - (Hans Goudey)
  • Add transform operations to keymap (commit) - (Hans Goudey)
  • Implement edit mode undo system (commit) - (Dalai Felinto)
  • Implement new operators
    • Duplicate operator (commit) - (Hans Goudey)
    • Selection pick operator (commit) - (Hans Goudey)
    • Separate operator (commit) - (Hans Goudey)
    • Join operator (commit) - (Hans Goudey)
    • Delete operator (commit) - (Dalai Felinto)
    • Select Random (commit) - (Dalai Felinto)
  • Support view selected operator in edit mode (commit) - (Hans Goudey)
  • Integration with transverts (cursor snapping) (commit) - (Philipp Oeser)
SVG
  • Batch import SVG as curves files (commit) - (Maxime-Cots)
UI
  • Vertically Aligned Grip Icon (commit) - (Harley Acheson)
  • Add Icons to Represent Error Conditions (commit) - (Harley Acheson)
  • Skip Internal Operators For Idle Status Bar (commit) - (Harley Acheson)
  • Rename ‘Inverse’ to ‘Invert’ in File/Asset Browser (commit) - (IREXTIA)
USD
  • Improved sanitation of names with leading digits (commit) - (Jesse Yurkovich)
  • Add Capsule_1 and Cylinder_1 Shapes to USD importer (commit) - (Maxime-Cots)
Undo
  • Add explicit filtering for IDs and RNA structs marked as skippable (commit) - (Sean Kim)
Weekly Reports
