14 August 2023
14 August 2023
Modules & Projects
New Features and Changes
USD
  • Generic Attributes Support (commit) (Charles Wardlaw)
  • Add export support for invoking Python chasers (commit) (Michael Kowalski)
  • Hydra
    • Export USD preview surface for materials (commit) (Brecht Van Lommel)
Nodes
  • Previews
    • Add node previews in the shader editor as an experimental feature (commit) (Colin Marmond)
    • Hide the node preview button when the overlays are disabled (commit) (Colin Marmond)
    • Add ability to preview shader output nodes (AOV, group, material) (commit) (Colin Marmond)
    • Use flat previews for shader nodes by default (commit) (Colin Marmond)
    • Stop the shader preview job when changing the viewed nodetree (commit) (Colin Marmond)
  • Add “Floored Modulo” mode to Math nodes (commit) (Hoshinova)
Vertex Paint
  • Add option to lock alpha for ‘Set Vertex Colors’ (commit) (Philipp Oeser)
User Interface
  • Update industry compatible keymap for consistency (commit) (Julien Kaspar)
  • Right align slider unit text (commit) (Christoph Lendenfeld)
Cycles
  • Rework component layering in Principled BSDF (commit) (Lukas Stockner)
Animation
  • Blend To Ease Slider (commit) (Christoph Lendenfeld)
  • Blend Offset Slider (commit) (Christoph Lendenfeld)
  • Improve FCurve drawing performance (commit) (Christoph Lendenfeld)
Grease Pencil V3
  • Allow buttons for child nodes to be inactive (commit) (Falk David)
  • Animation
    • Display layer properties in animation channels (commit) (Amelie Fondevilla)
    • Transform action for grease pencil frames (commit) (Amelie Fondevilla)
    • Include summary and datablock keyframes in the grease pencil dopesheet (commit) (Amelie Fondevilla)
    • Include other channel selection modes (commit) (Pratik Borhade)
Geometry Nodes
  • Don’t delete parent simulation bake directory (commit) (Falk David)
Library Overrides
  • Add ID pointer to operations over ID pointers (commit) (Bastien Montagne)
  • Remove an override property when it has no operations (commit) (Bastien Montagne)
Color Management
  • Add and rename colorspaces (commit) (Zijun Zhou)
  • Improve no-op color space detection (commit) (Sergey Sharybin)
  • Refactor OCIO config to be CIE XYZ I-E based (commit) (Zijun Zhou)
Core
  • macOS
    • Enable support for EDR rendering (commit) (Jason Fielder)
  • Remove compatibility code for blendfiles from early 2.80 development (commit) (Bastien Montagne)
Video Sequence Editor
  • Improve drawing of strip title and preview (commit) (Richard Antalik)
EEVEE Next
  • Irradiance pool size (commit) (ClĂ©ment Foucault)
  • Irradiance grid compositing (commit) (ClĂ©ment Foucault)
Python API
  • Add preferences.filepaths.extension_repos.new/remove methods (commit) (Campbell Barton)
  • Support passing None to imbuf.load(..) for consistency (commit) (Campbell Barton)
  • Add-on name-spacing for extension repositories (commit) (Campbell Barton)
Weekly Reports
Google Summer of Code
