VSE compositing effect strip (suggestion)
So i think that blender’s video sequence editor is probably the best of all the free video editors out there. But it has two minuses. First is that it is pretty laggy, but i can deal with that. But the second is that blender’s VSE is really lacking of effects. So what i suggest is a new video editor strip called compositing strip that you will be able to add on top of the existing video/image strips (something like transform strip). And you will be able to edit each compositing strip. When editing compositing strip it will be like compositing window with image input node and output image node and between those nodes you can place any nodes that you can get in compositing window. So you can create any effect you want and like transform strip compositing strip will replace video with one that has all nodes applied. I thin this strip will really improve blenders video sequence editor by allowing user to make any custom effects they want. I would glad to hear your thoughts about my suggestion.
