Could we have a simple “ZMode” button in sculpting mode that allows to toggle 3d navigation and brushes shortcuts to mimic ZBrush ones (shift / ctrl / alt + left click ones) in the industry compatible key-map ?
Those are the best and definitely industry standard sculpting shortcuts, and it would be nice to have them available (and not maya ones for this part of the process).
Yes that is something I always wanted to add at some point.
The IC keymap could have keymap preference options to tweak it to make it work more like specific apps. There could be a option to make it mirror Houdini, C4D or ZBrush, for example.
No there is a conflict. It’s impossible to trigger Scale Cage with it’s DIRECT shortcut in Object mode, because there is a conflict between Scale Cage that was on Shift+R and Keyframing Scale Track what also was on Shift+R.
That conflict is not new and was nothing dramatic and as it still worked in Edit Mode, but the keyframe-shortcut prevents the scaling one from working partially.
You should also not activate cycling for the Scale Cage shortcut on “Shift+R” as that makes more sense (triggering scale cage in edit mode directly) , currently its degenerated to being a duplicate of “R”
No I did not, and I’ve reset it to factory settings and once again to doublecheck before posting. Also it’s listed in your commit to the keymap several times.
Combinations of modifier keys (Ctrl/Alt/Shift) in PolyBuild do not seem to work well when using industry compatible keymaps. (It looks like the view is not updated.)
Is there a way around this problem?
Ok yes, you are right - sort of. There was an entry for the Scale Cage tool, which in practice wasn’t assessable because Shift-R would set Scale keyframes, and now it’s not necessary due to the cycling working when you repeat the tool key shortcut. The shortcut for Scale Cage has been removed now.
Btw, now the tooltips properly show the shortcut key for cycling tools:
The problem seems to be that the Gizumo display does not update when the modifier key is pressed. I found that not only PolyBuild, but also all tools no longer highlight Gizumo.
The same goes for add-ons. For example, the same symptoms can occur with the standard “Snap _ Utilities _ Line”.
As I am still a bit into tweaking my own custom keymap. I found some more points worth changing for everyone using this keymap. I hope you can agree.
There is little inconsistency in the different EditorTypes fot the View Frame Function. Most rely to Numpad 0 like the blender keymap but the GraphEditors View Frame is set to Shift+A. I’d change that back to Numpad 0.
Another Shift A is used in 3d-view für View All for All Regions
I’d remove that completely as it’s not much needed and just works with quadview and at least currently not at all with multiple 3dviewports (but would make sense). So I’d say the view menu entry is enough for that.
What I’d propose is to set the new Mask Expands to Shift+A and Alt Shift+A for Sculptmode as it is also in the Blender Keymap. They can’t be triggered from the menu in a way that makes sense, because the mouse position at the moment of triggering is the initial selection start point. No need to think about other shortcuts than blenders default-keymap ones here. They fit nicely to the IC KeyMaps Ctrl+A and Ctrl+Shift+A.
Yes I can confirm that knife tool problem too, the second tool switch has to be done with the keyboard shortcut as hovering over the vertical toolbar leads to an updated cursor
Not sure if this relates to the PolyBuild tool problem. I haven’t tried regularly, but I am pretty sure I never saw it really working with the ICKeymap til now.
At least in my case a lot of the tool isn’t working as expected under IC Keymap:
Strange. It was definitely not working. Perhaps the prebuilt version I had installed was a day or so too old. Can’t reproduce it anymore as I’ve updated meanwhile. But it’s there now. You are completely right. Sorry if that caused inconveniences. Thanks.
Edit: My post and your commit with the remeshing shortcuts were both on 12th December. So it very likely wasn’t in the downloadable build that day.
Oops accidently typed the wrong word, sorry didn’t reread it, wanted to say toolbar ( the vertical one in the 3dviewport). I think especially things like vertex slide and edge slide and the two rip tools would benefit from cycling shortcuts.
Blender 2.82 Alpha December 15, 00:23:19 - dfe965bee24d - Windows 64bit build
2 wrong mappings for Context Menu in Sculptmode ( RMB and Keybord ContextMenuKey) - IC Keymap (it’s working with Blender keymap)
due to mapping to wm.call_menu instead of wm.call_panel with Name: VIEW3D_PT_sculpt_context_menu
Edit: Now I see this also happens in Texture Painting Workspace , so you better check all recent changes to the context menu mappings you commited.
Hi @billrey. The Skin_Resize is a thing that would be great if it could find it’s way into this keymap. Ctrl+Alt+R could be a good shortcut, thats free in edit mode, that makes it related to the scale shortcut.
( ID: transform.skin_resize )
Perhaps it could also be added to the vertex context menu to make this feature more discoverable.
Btw. is there another mode available/planned for skin_resize so we could switch to that mode permament, like the other transform tools ( move,scale,rotate)? It could get an icon and put next to scale and scale_cage.
Is there any reason that the view menu still remains in poor state even after such a long time?
The rarely used direction such as bottom still occupies main angles while frequent ones like Front are present in awkward diagonal angle.
On top of that, the view menu contains view selected entry which is already mapped to F key while at the same time lacking Perspective/Orthographic toggle which currently has no key in this keymap.
Just swap positions of Front and Bottom and replace view selected with Perspective/Ortho toggle and it will actually become usable.
Also, Alt+C activates some weird version of Loop Cut where mouse wheel doesn’t change amount of cuts and the highlight is jagged and not antialised, while right click context menu activates the tool of very same name, but mousewheel cut count adjustment works and the highlight is antialised.
