GSoC 2025: Glare Node Enhancement
Name
Mohamed Hassan Gad
Contact
Blender Chat: @hassan
Synopsis
This project aims to enhance Blender’s Glare node by addressing UX and technical limitations, improving usability, and performance. By resolving long-standing issues such as unintuitive controls, resolution dependency, and bad performance particularly in modes like Simple Star and Streaks. The updated Glare node will offer a more intuitive and efficient implementation.
The general improvements I aim to implement are stated in the following task:
Compositor: Future of Glare node
The Glare node suffers from UX and usability problems as evident by the feedback received on the new Bloom mode, as well as the flourishing of third party glare implementations; which is great, but a telling sign that the built-in solution is not…
Project size: 350 hours.
Deliverables
General Improvements
Problems:
The quality setting sometimes affects the final size of the Glare, and causes shifts in the highlights, modes like streaks and simple star implementations are directly dependent on the quality setting.
Solution:
  1. Re-implementing features to be independent of the quality sitting.
  2. Using a higher quality down sampling filter would preserve more details mitigating shifting of highlights.
Streaks Mode Redesign
Problems:
  1. Slow computation, where in the current implementation the compute kernel is dispatched as many times as the number of iterations specified by the user.
  2. Unintuitive control.
  3. All streaks are simply added, creating a bump at the center of the filter.
  4. Resolution dependency.
  5. Arbitrary filter impulse response.
Solution:
Designing a recursive exponential filter with adjustable parameters to control both the rate of change and the filter’s curve support (i.e., its radius). Reference [1] presents insightful equations that can serve as a foundation for developing this filter, with the following graph closely resembling our desired impulse response (the green curve).
Figure 1: Plot of a point spread function discussed in reference [1].
Also as discussed previously in the general improvements section (quality setting independent features); the radius parameter will be implemented resolution independent.
Also for a more realistic and intuitive result, at the center of the streaks instead of simply adding the streaks we would take the maximum in the overlapping region.
Finally simple star would be re-implemented as a special case of streaks (at streaks = 4), where the Gaussian-like impulse response would be an exponential response.
Fog Glow
Implementing the kernel discussed in reference [1] “Physically-Based Glare Effects for Digital Images”.
Sun Beams Integration
Problem: Redundant node and slow computation.
Solution: Integrating the Sun Beams node into the Glare node as a new mode, optimizing it with Monte Carlo line integration for improved performance similar to the approach used in the Lens Distort node. Additionally, introduce a “Distant Light” mode, where rays remain parallel, potentially leveraging streak-based methods.
Custom Kernel Support
Add an option to use a custom glare kernel to be convolved with the highlights using FFT similar to the Fog Glow implementation.
Documentation
  • Update user manual with new parameters and workflows.
  • Provide technical documentation for future contributors.
Implementation Timeline
#Phase Approximate time interval Task
Phase 1 Week 1 General Improvements
Phase 2 Week 2 Custom Kernel
Phase 3 Week 3 Fog Glow
Phase 4 Week 4-5 Sun Beams
Phase 5 Week 6-11 Streaks, Simple star
Phase 6 Week 12 Bug Fixing And Documentation
Total: 350 hours.
Biography
I am a research and development engineer working on an automated handling system project, and a master’s degree student majoring in flight dynamics and control in aerospace engineering department. I earned my bachelor’s degree in Aerospace Engineering from Cairo University in 2022.
I love mathematical challenges, and have been working through my bachelor degree on many different projects that involved implementing various mathematical solutions and algorithms predominantly using MATLAB, and occasionally in C or C++.
I am eager to contribute to GSOC, particularly Blender’s compositor project to improve my code writing capabilities while implementing different mathematical solutions.
As a first contribution to the Blender foundation I committed the following PR [95eee272fe ] where I had the opportunity to build an understanding of the overall architecture and structure of Blender’s code base.
References
[1] G. Spencer, P. Shirley, K. Zimmerman, and D. P. Greenberg, “Physically-based glare effects for digital images,” in Proc. 22nd Annu. Conf. Computer Graphics and Interactive Techniques (SIGGRAPH '95), 1995, pp. 325–334, doi: 10.1145/218380.218466.
Proposal Draft: GSoC 2025 Draft Proposal - Compositor: Glare Node Enhancement
Week 1
In the first week, I focused on the pull request I had previously opened: “Fix #134658: Lens Distortion node turns transparent areas black.” The fix is nearly complete—only one of the tests still needs to be updated.
During this process, I encountered and resolved several issues, particularly related to Git workflows and Blender’s code review standards. While I made a number of mistakes early on, they provided valuable learning experiences in areas such as version control and commit formatting.
This week, I was able to work for three days only, as I had previously requested time off from June 5th to 9th to observe Eid al-Adha.
Lastly, I’d like to note that my academic year is still ongoing, and I will complete my final exams after June 25th. Once the exams are over, I expect to significantly improve both my availability and overall productivity inshallah.
Week 2
We successfully completed the first deliverable — the down-sampler — which has been implemented and merged. Additionally, the lens distortion pull request mentioned in Week 1 has now been reviewed, closed, and merged as well.
Many thanks to my mentor, Omar, for his continuous support and guidance.
I’ve now started working on the fog-glow improvement. This involves reading the main paper intended for implementation "“Physically-based glare effects for digital images”, along with additional references, as the topic includes several technical expressions and concepts that I’m currently unfamiliar with.
