The new user should never ever go to standard, the standard use case is VERY specific, in your anime image the character is burned out in the shoulders, and there is no way to avoid that, that burn out is also present in the eyes or the noise, if you want more contrast use the high contrast profile, but to get proper colors you should learn to use Filmic.
If you go outside and make a photo of a house with a white wall during a sunny day, and during a cloudy day, and then you put one besides the other the wall won’t be of the same color in the picture AT ALL, Standard is not a good way of working, you will get over saturated colors, under exposure and over exposure in lighting.
A new user is that, a new user, and as a new user that new user has to learn why has to use Filmic, not rely on Standard because when it configures a red in the material it looks red in the render… it should not… light is everything and interacts with the material, and management is there to allow us to properly work with screens that are so limited that can’t show nothing not even similar to real color, no matter if you work with cartoon or with a photorealistic scene.
