Blender user interface design
How about a more regular topbar, filled with the most usual stuff, as seen on most 3d apps?
Tbh, this is the kind of stuff I expect from a topbar, not settings.
Example:
Thx.
For now all modes can hold all settings & tool buttons inside one row. But in case of " Compact " interface layout i think it can be more compact. Buttons already can include few options inside one button. Maybe it is reasonable to merge some of settings together?
Obviously, you have no clue on what’s happening. So why are you opening a WIP editor and complaining about it then? It makes no sense, you’re just making noise
Have you at least searched on developer.blender.org or old 2016’s 2.8 workshop writeup in order to at least understand what they might be trying to do?
If not, that is the first thing you have to do. You can’t criticise an unfinished work you’re not even aware about.
Otherwise, as said @DanPool :
No one is forcing you to use 2.8. If it’s making you this hostile, maybe you should wait until final release before you open it again.
I know whats hapening, I just dont understand why would devs hardcode UI stuff if there are editors, They did it with properties editor, why not do it with everything else, Blender’s UI main philosophy was always:
100% Customizable.
Specially, I dont understand why would devs take the info editor’s header and put on a locked ui region while everything they needed was just to split the timeline and set to INFO EDITOR.
Its like 100% more work while they only needed to change a editor tipe on the startup file (NO CODING AT ALL)
I agree 100%.
This is the best topbar solution so far…
Dont forget the custom factor.
That would be a christmas gift from the devs… :joy:
We have a new “favorites” quick menu. It works really well.
So I just found about favorites menu. Super useful!
Favorites menu might be the most impactful thing so far in terms of speeding up work in 2.8! Could we have this with favorites pie menus also?
I’m certain they will implement it as part of the pie-menu worflow.
Favorites should also include some type of macro recording like photoshop action-recording… nowadays if I want to perform 2 subsequent actions instantly, it’s impossible to do it AFAIAK, I can only redo the last action, not the last two or three actions.
That’s not true. You have plugins to make that. Also that you can open the info area, copy the necessary commands and create a custom script.
Sure, obviously I meant a directly integrated UI-way of doing it… we can do almost anything using scripts… could add primitives on the scene only by means of plugins or scripts, doesn’t mean that we should do it instead of shortcuts
default theme is nice. but text shadow make text not clear text
default theme :
w%20shadow
default theme no shadow text :
wo%20shadow
it’s clear whithout shadow :slight_smile:
or whith shadow brightness =0 :
text%20shodow
it’s make text bold and clear
default node selected not clear :
change to white is clear :
default theme widget emboss :
w%20embos
widget emboss alpha 0 :
w%20embos%20alpha%200
nice flat
Hi folks! I’m digging into UI look tweaking. Just updated my proposal for better toggles in panels. Fill free to share your thoughts :slightly_smiling_face:
The icon version looks really good!
My concern about that design though is that it might make it more difficult to find stuff at a glance: having some breaks throughout the interface with different sizes or alignments I think would helps you to get a visual memory of the panels.
The X-V icons or the selection colour may compensate that though, the only way to find that out would be to try it for some time I guess :slight_smile:
default theme selected text:
color selected is black need more contrast
more bright:
contrast is ok
Short demo of my working UI proposal: showing alot of context sensitive tools and pie menus/popups focused on faster modelling, reducing clicks and clutter.
I think the favorites menu is a huge step in the right direction, pie and popup functionality for favorites would be amazing.
