So I saw the 2.81 batch renamer and I donât think it can do anything I need. So I made a quick sketch that shows something that can do 99% of the name operations I usually need. What I need is suffixes and prefixes with removal of .001 suffixes so Ican produce short descriptive object names.
One thing I left out is that you should be able to write your prefix and suffix directly into the text boxes. For example for numeration you could just type ## which adds a double digit (01-99) to that slot.
#r could be in reverse order (9-1). But it is important to have graphical user interface so it doesnât take 10 minutes of googling to figure out the codes but codes should be also available as it is faster if you need to use the renaming often.
