Blender UI paper cuts
Hello! I have a problem seeing selected edges when the edges have bevel weight, crease or seam edges values. When the edges have values of crease, bevel weight and you need to select them it’s getting really hard to select those edges precisely, most of the times selection is barely visible in both solid and wireframe modes and this is not a theme color settings issue.
In the screenshot attached to this message you can observe the following situation:
  • I have red as my active color for selected edges and deep blue for active selection for face, edge, vertices.
  • Bright blue color has been set up for mark sharp, mid-blue for bevel weight, purple for crease and green for seam edges.
  • As you can see from the screenshot whenever the affected edges are! selected, the edges with edge bevel weight, mark sharp override the color of selection sometimes almost completely, making your selection barely visible.
Proposal:
  • Make selection of bevel weighted, crease, mark sharp, seam edges overridable by users selection to make everyone’s life easier. Thank you!
