Here:
Using ICK I searched the scene and found roughly 50 objects starting with “apts”, like this:
How do I select them now? I would expect that as soon as I press enter, they are selected, but that is not the case. I can only select them one at a time
When pressing Q, I can only select the ones that fit into the height of the outliner UI panel. How do I perform selection on ALL of the found objects? A feature every other outliner out there has? How do I select ALL the objects highlighted in green at once?
