Blender 4.2 - EEVEE-Next Feedback
I join the hordes of those who are super eager to test EEVEE Next but can’t even start without the Shader To RGB node.
I would like to stress that for many of us the Shader To RGB isn’t a minor curiosity but a huge part of our Blender workflow - and one of the major selling points that make EEVEE so unique (and so envied) in the 3D world:
https://twitter.com/yattytheman/status/1649684425507057664
“I think the great advantage of blender for npr is the “shader to RGB” node cuz you can use the way an object reacts to light as a color pass for masks, textures and other effects”
“BRO YES i love the shader to rgb node! dont get me wrong, i would love it if it were in cycles, but eevee is already lightyears ahead of c4d.”
“Im just toying with c4d and redshift’s terrible support for non realistic shit and blender keeps pumping out bangers”
“So good. Reckon you’ll start moving to blender at some point ? Surely its gonna become industry standard within the next few years…”
Cant find the thread now… and i have not checked the code but shader to rgb is quite a hack to get it to work and can break with complex setups… There is probably a proper way to implement it but would need more work to do so…
Photorealism is a hack .)
In many different (and sometimes unpredictable) ways, the Shader to RGB node is part of the workflow of thousands and thousands of NPR artists around the globe. It would be a shame not not to prioritize this aspect of what makes EEVEE so unique and so far ahead of the competition.
You dont understand the point… I am not against it but it can break easily…
It doesn’t matter if it can break- for Eevee Next to have feature parity with Eevee (the stated goal), it must have Shader to RGB. As it stands, Eevee Next cannot replace Eevee
Yeah! I’ve invested 3 years of my life in a style deeply based on the Shader to RGB for my next short animation… hope there’s a way to keep it!
For me, Shader to RGB is not an optional… It is as integral to my work, as noise samples are for a Cycles user.
I’m not saying that I can’t conceive of embracing a new solution, that would involve a new shader that accomplish even greater things. But for NPR artists, that shader node is not just a convenient “hack” for us. Without the ability to achieve that shading result, most of us would probably not use Eevee Next… Which, I don’t imagine is the goal for us to be abandoned.
Given that multiple sessions at bcon 2023 literally involved npr, I hope we will see Eevee Next re-add these features soon. :slight_smile:
Captura de ecrã de 2023-11-15 17-33-29
I apologize but I’m not getting it… doesn’t this says that it’s done!? :thinking:
Yeah, but it doesn’t work
I’ll take a look in the 4.1 version just released, maybe it’s been addressed? If so, awesome…
ok, just checked in 4.1, comparing Legacy to Next.
Shader to RGB in Next improved, in that it no longer makes everything Black. But, it’s not behaving as in Legacy; it seems to not evaluate correctly if a color ramp is next in the chain. Or something.
Sorry, it’s hard to troubleshoot and eval a material/feature when you don’t know what is expected to work, and what isn’t done yet.
So it looks like it’s still perhaps in coding/updating mode.
Thanks for giving it a look @thorn-neverwake! :slight_smile:
Feels as good news, at least is clear evidence that ain’t forgotten.
And please, definitely never take my thoughts on the state of alpha stuff as always accurate without any doubt… I know everything is in a state of flux, so I would hate to say something that mislead someone else, due to either me phrasing it poorly, getting it wrong, or just making a weird typo.
Can you share pictures of Legacy vs Next?
Here we go. Shaders are assigned the same in both scenes; i just changed the active object in each image, so both materials trees could be seen. No changes made in the scene itself, except switching from Legacy to Next.
The ground image is easier to see sort of what’s happening. It doesn’t go full black, but it only does eval on the initial ramp stop. It’s sort of like overall it’s only generating a single shader value - like, only diffuse or only diffuse falloff (not sure which would be the correct description.) Obviously not interpolating between the two, though.
Thanks for your time to capture this comparison! This makes the issue crystal clear.
I was just trying a hair shader I found online and noticed that alphas for hair card textures do not work in Eevee Next.
Eevee:
Please keep on topic. We are daily reading the feedback and change our priorities accordingly. We are on track to ensure that most important feedback will be addressed as described in the original post.
Due to dependencies both technical and planning wise the order we fix issues might not be what you expect. This is because development time is scarce. We optimize developer time to ensure that Blender 4.1 would get most fixes in and then some.
Hi, this one I didn’t find in known issues, although it’s quite obvious, please correct me if I’m doing something wrong.
Metallic reflections with roughness look dull and “washed-out” and reflections look quite different compared to legacy Eevee (these are printscreens of viewport, renders had noise issue).
Done with 4.1 alpha from today.
Is this something being worked on, is it Shader or new Eevee issue? Or known/accepted behaviour?
Especially car paints suffer greatly from this.
Thank you for your work.
Edit: Forgot to mention Cycles is very close to legacy, which I consider “ground thruth”. also non-metallic rough reflections suffer from this.
The hair shader in your screenshot includes a node group. Without being able to see all the nodes used by the material, there is no way to determine what the problem might be… so, try to expand all the groups, then remove as many nodes as possible to the point that the problem can be illustrated, and the cause targeted to a specific node or combination.
Was there any changes to SSGI denoiser too?
I assumed the difference below is a part of the issue caused by introduction of horizon scan yesterday.
SSGI difference, horizon scan disabled
Before b24610053fbc
After a13696a242fb
But after comparing the shots with no denoising, it seems the changes alleviated the darkening issue of temporal accumulation option.
Also it seems disabling SSGI does not disable horizon scan. Or maybe the option is no implemented yet.
