5 July 2021
Announcements
Modules and Projects
Geometry Nodes:
New Features and Changes
Constraints
  • Support a new Local Space (Owner Orientation) for targets. (commit) (Alexander Gavrilov)
  • Implement ‘Remove Target Shear’ and more Mix options in the Copy Transform constraint (commit) (Alexander Gavrilov)
Mesh Editing
  • Performance Improvements
    • Skip edit-mesh duplication for most BMesh operators (commit) (Campbell Barton)
    • Support multi-threading for bend transform (commit) (Campbell Barton)
    • Support multi-threading for most transform modes (commit) (Campbell Barton)
Geometry Nodes
  • Initial attribute list for meshes (commit) (Jacques Lucke)
  • Curve primitive nodes (Johnny Matthews)
  • Add mesh input warning to curve to mesh node (commit) (Hans Goudey)
Video Sequence Editor
Grease Pencil
  • New modifier to generate weights dynamically (commit) (Antonio Vazquez)
  • Add weight factor to Offset randomize (commit) (Antonio Vazquez)
  • Line art modifier
    • Occlusion effectiveness support (commit) (YimingWu)
    • Allow filtering intersection lines using mask numbers (commit) (YimingWu)
    • Use separate sub panel for line types (commit) (YimingWu)
Cycles
  • Reduce shadow terminator artifacts (commit) (Mikhail Matrosov)
User Interface
  • Add the ability to see all view layers in the outliner (commit) (Dalai Felinto)
  • Hide collection tab when scene master collection is active (commit) (Yiming Wu)
  • Do Not Resize Already-Open Temporary Windows (commit) (Jesse Y)
Miscellaneous
  • Apply random selection precisely for curves, lattices & objects (commit) (Piotr Makal)
Weekly Reports
