User Interface Module Meeting 2024-12-17T16:00:00Z
Regular User Interface module meeting for planning and coordination. Last regular meeting was December 3rd, next meeting January 14th.
Attendees
- Harley Acheson
Merged Since Last Meeting
- Fix #99157: Allow Shortcut on Auto Keyframe #131406
- UI:
PreferenceThemeSpacePanel
internal cleanup #131390 - Fix #78371: Allow Deleting Items When Measure On Gizmos Off #131340
- Refactor: Simplify Block Re-centering #131464
- Fix #125035: Stop widget_box from Drawing over Contents #131525
- Fix #130402: Improve Tooltip Text Colors for Light Themes #131515
- UI: Correction to #131406, Auto Keyframe Notification #131454
- Fix #131366: Outliner: Support ctrl/shift operations for exclude collection #131423
- Fix #131561: Adjust for Width of Modifiers in Status Bar Items #131584
- Fix #80356: UI Icon Alpha Should Not Affect Matcaps & Studio Lighting #131690
- Fix #88236: When Tabbing in Block Skip UI_HIDDEN #131698
- Fix #93769: Improved File Browser Button Tooltips #131703
- Fix #131422: Remove
OPTYPE_UNDO
flag for cursor snapping operators #131427 - Fix #131751: When Merging Areas Clear Screen.active_region if Active Area Changes #131994
High Severity Bugs
- Shortcuts to change “Editor Type” does not remember previous choice #130372
- EXCEPTION_ACCESS_VIOLATION when closing area on panel expanding or collapsing transition #130171
- Brush assets shelf disappears when thumbnails are enlarged enough #129412
- Zooming with Ctrl+MMB on a Tree-view messes up hierarchy lines #132386
Module Roadmap
Winter of Quality
- HackMD page
- Open Reports: -74
- Open Bugs: -55
- Needs Dev Info: -12
- Harley will continue on with above
Review
- Fix #129579: Improvement to Changed Brush Display #131119
- Fix #79977: Light Theme NumSlider InnerSel #131338
- UI: Reduce Light Theme Icon Border Opacity #131396
- Fix #59358: Don’t Show Status Bar Impossible Confirms & Cancels #131336
- Fix #79388: Increase User Scale Hard Min to 0.5 #131688
- Fix #127231: More Space for Frame Column in Shape Key List #131887
- UI: Improve Status Bar Display for Mesh Point Normals #131586
- UI: Themeable RedAlert, Error, Warning, Info Colors #131127
- Refactor: Allow any icons for RNA_def_property_ui_icon #127780
