User Interface Module Meeting 2024-12-03T16:00:00Z
Regular User Interface module meeting for planning and coordination. Last regular meeting was October 21th, next meeting on December 17th
Attendees
- Julian Eisel
- Hans Goudey
- Harley Acheson
Merged Since Last Meeting
- UI: Win32 - Clipboard Image Paste from File Path #127782
- Fix #129178: Opening the context menu on a numeric input shows the wrong cursor #129455
- Fix #130478: Toolbar tooltips have uncentered vertical padding #130498
- Fix #130579: Un-isolating collection fails in presence of linked-collection #130604
- UI: Area Move Snap to Min and Max #130702
- UI: Misc Changes to Area Splitting Operator #130706
- Fix #130686: Outliner vertex groups sorting is broken #130750
- Fix #129478: Remove Timeline Scrollbars For Tiny Areas #130764
- UI: Slightly Softer 50% Split Snap #130800
- Fix #130732: Join/Dock Tag Redraw on Secondary Participants #130801
- UI: Show File Name on Recent Item Tooltip #130875
- UI: Improved Calculation of Width of Collapsed Node Title #130936
- Fix #130998: Crash changing Color Palette in Object/Edit/Pose modes #131031
- Fix #130385: Use Only Advance When Measuring Mono Text #131114
- Fix #131017: Improve Subframe Tooltip #131115
- UI: Use Separate Mouse Cursors for Join Operations #131167
- Fix #128419: Allow the Positioning of Centered Dialogs #129125
- UI: Fix Broken Menus after #129125
High Severity Bugs
- “Shift+Space” in sculpt mode does not play animation #130853
- Shortcuts to change “Editor Type” does not remember previous choice #130372
- EXCEPTION_ACCESS_VIOLATION when closing area on panel expanding or collapsing transition #130171
- Brush assets shelf disappears when thumbnails are enlarged enough #129412
Module Roadmap
- Concentration on current bug reports as part of the “Blender Winter of Quality”
- Bug and general reports, not paper cuts
- Classification of existing bugs. Add tags for UI “sub modules” (Outliner, keymap, etc)
- Close old reports already resolved
- Fix by related area?
- HackMD page with summaries and counts
- Setting targets for reports closed, resolved
Review
- Fix #128966: Update Dopesheet Playhead in Separate Window #129131
- Julian will look at.
- Core: Fix Incorrect FP Precision With “None” Units #130358
- Core: Increase Float Precision to Seven Digits #130359
- Platforms: X11 Implementation of getWindowUnderCursor #130351
Design & Discussion
- Help Needed With RTL & Complex Language Support
- Harley has emailed the creator of Harfbuzz
