User Interface Module Meeting 2024-11-21T16:00:00Z
Regular User Interface module meeting for planning and coordination. Last regular meeting was October 8th, next meeting on December 3rd
Attendees
- Demeter Dzadik
- Hjaiti Hjalmarsson
- Julian Eisel
- Pablo Vazquez
- Hans Goudey
- Nika Kutsniashvili
- Harley Acheson
Merged Since Last Meeting
- Expose lock_rotation in the view menu #122185
- UI: Fix missing hyphen in “Addon Tags” label #127822
- Fix #128616: Allow Docking to work from Menu shortcut #128730
- Fix #128112: Improve Display of Drag Overlays #128623
- Fix: Improve Blurry Text 3DView Drag Name #128809
- Fix #122206: Int soft limits changed to 10000 #123223
- Fix #128868: Hide Sharp Corners in Docking Split #128901
- Fix #128906: Remove Docking Draw Callbacks After Deactivate #128957
- Fix: Docking Called from Shortcut Without Status Bar #129187
- Fix: GPv3: Update active layer icon in context menu #129450
- Fix #130365: Hard to read brush names in Blender Light theme #130366
- Fix #129414: On Linux, Join Use Active Window when Overlapping #130242
- Fix #130365 : Hard to read brush names in Blender Light theme #130366
- UI: Changes to Docking Operation Descriptions #130554
- UI: Minimum Docking Target Size #130546
- UI: Notification When Hiding Objects #130617
- UI: Face Orientation Front Color Transparent #130618
High Severity Bugs
- Regression: Cannot ‘un-isolate’ collection when a linked collection is also present #130579
- Shortcuts to change “Editor Type” does not remember previous choice #130372
- EXCEPTION_ACCESS_VIOLATION when closing area on panel expanding or collapsing transition #130171
- Brush assets shelf disappears when thumbnails are enlarged enough #129412
Module Roadmap
Review
- Fix #128419: Allow the Positioning of Centered Dialogs #129125
- UI: Win32 - Clipboard Image Paste from File Path #127782
- Fix #128966: Update Dopesheet Playhead in Separate Window #129131
- Core: Fix Incorrect FP Precision With “None” Units #130358
- Core: Increase Float Precision to Seven Digits #130359
- Platforms: X11 Implementation of getWindowUnderCursor #130351
Design & Discussion
- Short discussion of area splitting
- Hjaiti Hjalmarsson proposing changes to custom properties. Alpha order is a pain. Popup dialog is more complicated than necessary. Use a UI list? There are lots of room for improvement. Will do more work. A design task will be made.
- Nika Kutsniashvili proposes changes to keymap editor. A separate editor shown in own window. treeview to show
- Conference post mortem
- Andrew’s Video
- Docking Tweaks. Tooltip text, modifiers, min sizes, split action
- Notifications #130427
- There is a need to evaluate uses of “error” report level. We have too many.
- Julian would want error dialogs to be more visual dissimilar to other dialogs
- Changing Preferences Outside of the Preferences Editor #130425
