Date/Time: 2024-05-06T14:00:00Z
Link: https://meet.google.com/xxo-tyin-rem
Attendees :
- Amélie Fondevilla (LFS, Developer)
- Andry Rasoahaingo (Dedouze, animator)
- Antonio Vazquez (Developer)
- Casey Bianco-Davis (Developer)
- Daniel Martinez Lara (Grease Pencil team)
- Falk David (Blender developer)
- Lukas Tönne (Blender)
- Matias Mendiola (Grease Pencil team)
- Samuel Bernou (ADV Studio, Dev)
- Sietse Brouwer (Developer)
- Yiming Wu (Grease Pencil Line Art)
Topics
- Development updates
- Python API discussion
- Drawing attributes API functions
Meeting Notes
- Weight paint mode, overlay, and tools landed (Sietse)
- Sculpt tools landed (Lukas)
- Extrude operator landed (Amélie)
- “Draw on back” option for the draw tool landed (Casey)
Show all commits
- GPv3: Expose Shader FX in the UI by Falk David
- Fix: GPv3: Wrong reading of GP drawing ID reference by Brecht Van Lommel
- GPv3: Use GPv2 object mode flag for weight painting by Falk David
- GPv3: Overlay for Weight Paint mode by Sietse Brouwer
- Fix #120698: GPv3: Don’t move the first stroke point by Lukas Tönne
- Fix #120926: GPv3: Separate operator crashing because of missing layer by Lukas Tönne
- Fix #113925: GPv3: eval_frame needs to be updated for modifier result by Lukas Tönne
- Fix #117721: GPv3: write to vertex and fill color attributes by Lukas Tönne
- GPv3: Remove
OB_MODE_PAINT_GREASE_PENCIL
flag by Falk David - GPv3: Weight Paint tools (Draw, Blur, Average, Smear, Sample weight) by Sietse Brouwer
- GPv3: Implementation of sculpt mode tools by Lukas Tönne
- Fix: GPv3: Simplify positions and radii not working by Falk David
- Cleanup: GPv3: Remove wrap/unwrap macros for lineart by Falk David
- Fix: GPv3: Thickness modifier conversion of “uniform thickness” by Falk David
- Fix: GPv3: Redraw editors showing grease pencil keys when new on is added by Falk David
- GPv3: Fix initial selection mask of the grab sculpt tool by Lukas Tönne
- GPv3: Layer properties in dopesheet n-panel by Pratik Borhade
- GPv3: Wrong onion skinning icon in the dopesheet by Pratik Borhade
- Fix: GPv3: Division by zero for single point curves by Falk David
- GPv3: Fix initialization of the DrawingPlacement struct from tool settings by Lukas Tönne
- GPv3: Mask toggle in dopesheet channel by Pratik Borhade
- GPv3: Extrude operator by Amelie Fondevilla
- Fix failure to draw onto a surface with GPv3 by Campbell Barton
- Fix #121354: GPv3: object mode selection outline too big by Falk David
- Fix: GPv3: Allow compiler use of copy elision by Falk David
- GPv3: Draw tool: “Draw on back” option by casey bianco-davis
- Fix #121353: GPv3: Reset shading group pointers for polling in overlays by Lukas Tönne
- GPv3 will not land in Blender 4.2 LTS, it’s now postponed to Blender 4.3.
- There was a discussion about the Python API for GPv3:
- Sietse proposed two designs, 1) is behaves almost exactly like GPv2 and 2) follows the data layout of GPv3 more closely. See #116043 - GPv3: Python API - blender - Blender Projects.
- Both approaches have pros and cons
- Antonio: Thinks that it would be good to implement 2) and then add helper functions if needed on top.
- Falk: Also thinks that we should go for 2) but sees the issues with it.
- Sietse: Wanted to point out that he proposed 1) because it makes it easier for Python developers to think about.
- Falk: It would be good to have a prototype for 2) so that we can test it and figure out what the pain points are.
- We talked a bit about the drawing attributes API (#119080 - GPv3: Drawing attribute API functions - blender - Blender Projects):
- Sietse: Was wondering what the plan is. It’s currently a bit of a pain to deal with attributes as you have to know the name, the domain, the default, etc.
- Falk: Indeed the plan was to have functions for each of the built-in attributes on the drawing (for reading/writing). This way, the caller doesn’t need to know about any of the things mentioned. The problem is that this does not work when you don’t have a drawing, but e.g. the
CurvesGeometry
. In this case, we have the same issues as before. - This needs to be a bigger discussion about the attribute system in general.
- Falk: Will schedule another meeting about this with more devs.
- Antonio: Noticed a weird smoothing behavoir when drawing for longer.
- Falk: Sounds like a bug. Will investigate further.
- Antonio: Thinks it would be a good idea to remove the line tool. It’s basicallly the same as the polyline tool.
- Casey: There are only small differences (in the polyline tool, clicking adds a new point, in the line tool you have to press
E
; in the line tool, dragging will move the whole line, this does not work in the polyline tool). - Falk: Will wait for some more feedback. Otherwise if nobody is against it, we can indeed replace the line tool.
- Antonio: It would be good to have a way to control the rendered thickness of strokes in pixels.
- Falk: Agrees. Spent some time on testing if we can have a modifier (geo nodes group) that can change the thickness in camera space and give control over the thickness in the rendered image. Needs more testing.
- Casey: Was wondering about these settings in the perferences (what are they used for?):
- Antonio: These are old settings (probably for the early draw tool). Doesn’t think they are used anymore.
- Falk: Will check if they are still used. Otherwise we can remove them/replace them by tool settings.
Next Meeting
- Time/Date: 2024-05-20T14:00:00Z
