6 May 2024
6 May 2024
Announcements
Modules & Projects
New Features and Changes
Anim
  • Implement “Copy Driver to Selected” operator (commit) - (Nathan Vegdahl)
  • Add bone length property to Bone Properties Panel (commit) - (Frederick Solano)
  • Add RNA enum for animation bindings + operator to un-assign (commit) - (Sybren A. StĂĽvel)
Assets
  • Expose function to find asset from a weak reference (commit) - (Hans Goudey)
  • Add equality operators to AssetWeakReference (commit) - (Hans Goudey)
  • Sort assets by catalog (commit) - (Julian Eisel)
Compositor
  • Match size of Fast Gaussian with Gaussian (commit) - (Omar Emara)
  • Implement interpolation methods for Translate node (commit) - (Habib Gahbiche)
Cycles
  • Add thin film iridescence to Principled BSDF (commit) - (Lukas Stockner)
EEVEE-Next
  • Remove slope and quantization biases (commit) - (ClĂ©ment Foucault)
  • Move shadow resolution scale to the sampling panel (commit) - (ClĂ©ment Foucault)
  • Implement spherical harmonic deringing (commit) - (ClĂ©ment Foucault)
GPv3
  • Layer properties in dopesheet n-panel (commit) - (Pratik Borhade)
  • Mask toggle in dopesheet channel (commit) - (Pratik Borhade)
  • Extrude operator (commit) - (Amelie Fondevilla)
  • Draw tool (commit) - (casey bianco-davis)
Geometry Nodes
  • Unify menu switch with other nodes with dynamic sockets (commit) - (Jacques Lucke)
  • Add Align Rotation to Vector node (commit) - (Hans Goudey)
  • Support working with raw matrix values (commit) - (Iliya Katueshenock)
  • Add selection and depth options to Realize Instances node (commit) - (Arye Ramaty)
  • Show correct type in menu socket tooltips (commit) - (Jacques Lucke)
IO
  • Enable mesh validation by default for STL, PLY & OBJ importers (commit) - (Campbell Barton)
Linux
  • Only allow registering file association for portable builds (commit) - (Campbell Barton)
Realtime Compositor
  • Implement Fast Gaussian blur (commit) - (Omar Emara)
Sculpt
  • Polyline hide operator (commit) - (Sean Kim)
  • Add Line Trim tool (commit) - (Sean Kim)
UI
  • Add tooltips with description of compositing nodes (commit) - (Bartosz Kosiorek)
  • Rename New Bone Collection confirmation button (commit) - (Pablo Vazquez)
  • Add Modifiers submenu to 3D view header (commit) - (Hans Goudey)
  • Custom Text and Confirmation Button Text for Props Confirm (commit) - (Harley Acheson)
  • Use “label tooltip” as a fallback for quick favorites menu text (commit) - (Hans Goudey)
  • Enable “apply” handler for preview tile buttons (commit) - (Hans Goudey)
  • Check for object modifier support in operator poll functions (commit) - (Hans Goudey)
  • Tweaks to Object > Modifier menu (commit) - (Nika Kutsniashvili)
  • Option to store enabled asset shelf catalogs in preferences (commit) - (Julian Eisel)
  • Different Warning for Revert if Unsaved Images (commit) - (Harley Acheson)
USD
  • Small wording and layout changes for custom properties options (commit) - (Jesse Yurkovich)
VSE
  • Revert strip text color to white (commit) - (Aras Pranckevicius)
  • Make cache overlay visible to non “Developer extras” users (commit) - (Sebastian Parborg)
Weekly Reports
