2024-04-11 Animation & Rigging module meeting
The meeting will be on 2024-04-11T16:00:00Z. It is open for everybody interested to join the video call (link below).
Present: Bassam Kurdali, Christoph Lendenfeld, David W, Eduardo Rubio, Luciano Muñoz, Nacho de Andrés, Nate Rupsis, Nathan Vegdahl, Nika Kutsniashvili, Sybren Stüvel
Links
  • Change in workflow for developers: committing directly in main is going away, going via a PR is preferred. That way the buildbot can build, and we get less intrusive “oopsies” with unforseen inter-compiler differences.
Landed
Names are from the Git log. This list is limited to functional improvements & bugfixes.
Blender
incoming from others:
Technical Documentation
Ongoing Work
Active-and-unselected discussion
  • Sybren: people feel strongly about this both ways, some use active-but-not-selected as an easily togglable pivot point.
  • Nacho: could it be a toggle? Is in the same vein as left-click or right-click select. Sybren: could be an issue for developers, making workflows harder. Bassam: I’m against an option, but would be ok with it changing.
  • Luciano: despises the current can-be-active-but-not-selected
  • Bassam: agrees the current behaviour is confusing, especially to new users.
  • Nate: we can go for Brad Clark’s suggestion of actually implementing this, and seeing how loudly people complain :slight_smile:
  • Bassam: could there be a separate ‘highlight mode’ that makes it more clear that there is something active but not selected? Luciano: agrees, it’s hard to distinguish these bones. For objects it’s a bit clearer due to the visibility (or not) of the object origin.
Patches: Review & Decision Time
  • #120411: UI: No way to provocate real time updates of Scene Duration in Status Bar The current frame of the scene duration doesn’t update during playback. Is that something users are missing?
    • Christoph: redrawing the footer takes time, as it needs to also update mesh statistics.
    • Sybren: fine to keep it as it is now.
    • Luciano: Profiling & fast animation is important. In the viewport, showing the playback info (FPS) as efficiently, so without all the mesh stats would be good.
    • Sybren: so better not, as it’s just the frame number, which can be found in different places as well.
    • Decision: file as ‘known issue’, with the extra info that if it can be redrawn without re-fetching all the other info, that would be preferred.
    • Nathan: can imagine that memory usage during playback would also be nice.
    • Sybren: all the stats could be useful to see during playback, in certain cases, for certain people. So that shows this is not a bug, but a feature that should be carefully designed.
  • #119376: Theme colors for time visualization What colors should be used to display past/future data and where should that setting be located (personal theme, or somewhere in blend file, or both?).
    • Christoph: currently the colors are just picked from other theme colors, like the “active vertex color” for the keys on the motion path.
    • Christoph: chose pure red & green, because that’s what Krita uses. Sybren suggested this were “programmer colors”.
    • Nathan: likes a “heat thing” where things cool down over time: “warm” is for “before” and “cold” is for “after”. Sybren likes that.
    • Nika: Falk asked about this in the Grease Pencil module chat as well. Matthias Mendiola suggested red & green, because that’s what almost all 2D animation systems use.
    • Nacho: what does Grease Pencil use now? Consistency would be good. Christoph: muted green for “before” and somewhat purple for “after”. Nika: that’s an awful choice.
    • Nathan: for my type of red-green colorblindness, these particular shades are easily distinguished.
    • David W: Future blender orange, past, maya turoquiose
    • Nathan: not for this PR, but maybe some subtle motion in the color (like old-style palette based color shifts) would be nice to have, as an option.
    • Luciano: having speed/acceleration based colors would also be nice – for the future.
    • Christoph will make a PR with a test build, to see things in practice.
  • To re-visit & see where we are: #84901: Curves Interactions in the Graph Editor for another time.
  • Got some useful feedback about the Select Key / Handles operator in Select Handles operator doesn’t remember preferences from previous call #119487.
    • Should we add “Select Left Handle” and “Select Right Handle” to the graph editor selection menu as well?
    • Nathan: additionally, I think this partly comes down “it’s hard for users to create their own menu items for operators with specific parameters set”.
    • Nika can send a PR to add two more operator “Select Left Handles” and “Select Right Handles”.
    • Nathan: “Select Bone Handles” currently doesn’t de-select the key. For “Select {Left/Right} Handles” it should probably deselect the key.
    • Nika: The operators should probably just delesect the key and select whatever handle it should. With shift pressed it could then keep the keys selected as well.
    • Sybren: Might work well in a pie menu? Or with a toolbar with buttons & icons that visualise what they do. But that’s not really something the UI module likes.
    • Nathan will add the menu items.
  • #120519: Anim: don’t include handles when calculating FCurve bounds in Graph Editor How much are the scrollbar-sliders in the Graph Editor used and would it matter if they didn’t account for key handles
    • Making the scrollbars not take handles into account, makes the drawing 20% faster when there is lots of keys.
    • Bassam likes it, more than the possiblity of having to scroll
    • Christoph will make test build.
Help Needed
Next Meeting
The next meeting will be on Tuesday 2024-04-16T10:00:00Z. Again it will be open for everybody who’s interested. The provisionary meeting agenda will be updated before the meeting.
