15 April 2024
Modules & Projects
- 2024-04-08 Grease Pencil Module Meeting
- 2024-04-09 User Interface Meeting
- 2024-04-09 Sequencer meeting notes
- 2024-04-09 Compositor meeting notes
- 2024-04-11 Animation & Rigging module meeting
- 2024-04-15 EEVEE/Viewport Module Meeting
New Features and Changes
Alembic
- Support new Curves object type for export (commit) - (Jesse Yurkovich)
Anim
- Detailed report if no keyframes have been inserted (commit) - (Christoph Lendenfeld)
- Avoid loading alpha channel from theme for keyframe drawing (commit) - (Sybren A. StĂŒvel)
- Add new keyframe type âGENERATEDâ (commit) - (Sybren A. StĂŒvel)
Collection Exporters
- Enable file exporters to be specified on Collections (commit) - (Jesse Yurkovich)
- Add Alembic support (commit) - (Jesse Yurkovich)
Compositor
- Allow inter-operation canceling (commit) - (Omar Emara)
Core
- ID Management (commit) - (Bastien Montagne)
Curves
- Add operator to set bezier handle types (commit) - (Jacques Lucke)
- Add menu to add some primitive curves in edit mode (commit) - (Jacques Lucke)
EEVEE-Next
- Add back volume reprojection (commit) - (Clément Foucault)
- Add consistent support for thickness output (commit) - (Clément Foucault)
- Changes to thickness output (commit) - (CleÌment Foucault)
GHOST/Wayland
- Use discrete zoom steps with multi-touch disabled (commit) - (Campbell Barton)
- Resolve mouse wheel being treated like touchpad scroll (commit) - (Campbell Barton)
GPv3
- Deselect everything from all visible drawings when pasting strokes (commit) - (Pratik Borhade)
- Initial sculpt mode (commit) - (Lukas Tönne)
- Expose âUse Lightsâ option in the object data properties (commit) - (Falk David)
- Add option to disable masks in viewlayer (commit) - (Falk David)
Geometry Nodes
- Better support for tiny triangles in reverse uv sampling (commit) - (Jacques Lucke)
- Add invertable boolean output to invert matrix node (commit) - (Jacques Lucke)
- Use rotation socket in Curve to Points node (commit) - (Jacques Lucke)
- Avoid repeated node tools lookup when empty (commit) - (Hans Goudey)
- Log socket values for node tools (commit) - (Hans Goudey)
Nodes
- Display node label for tooltips on a free reroute (commit) - (Iliya Katueshenock)
PyAPI
- include a filepath in preset pre_cb/post_cb callbacks (commit) - (Campbell Barton)
Realtime Compositor
- Support variable scaling (commit) - (Omar Emara)
UI
- Splash Screen Import Changes (commit) - (Harley Acheson)
- Add Rename operator in bone collection context menu (commit) - (Pratik Borhade)
- Indicate type of search in keymap search button (commit) - (Julian Eisel)
- Consistent Cursor Color (commit) - (Harley Acheson)
- Remove active vertex theme option for 3d view and UV editor (commit) - (Pratik Borhade)
- Rename âQT rle / QT Animationâ to âQuickTime Animationâ (commit) - (Aaron Carlisle)
- Slight Adjust Last Operation Changes (commit) - (Harley Acheson)
- Add tooltips for inputs of vector shaders nodes (commit) - (Bartosz Kosiorek)
Weekly Reports
- Aaron Carlisle
- Bastien Montagne
- Campbell Barton
- Christoph Lendenfeld
- Clément Foucault
- Dalai Felinto
- Falk David
- Germano Cavalcante
- Hans Goudey
- Harley Acheson
- Jacques Lucke
- Jeroen Bakker
- Jesse Yurkovich
- Julian Eisel
- Lukas Stockner
- Lukas Tönne
- Miguel Pozo
- Nathan Vegdahl
- Omar Emara
- Philipp Oeser
- Pratik Borhade
- Raul Fernandez Hernandez
- Richard AntalĂk
- Sergey Sharybin
- Sybren StĂŒvel
- Thomas Dinges
- Weizhen Huang
- Wu Yiming
