User Interface Module Meeting 2024-03-12T16:00:00Z
Regular User Interface module meeting for planning and coordination. Last meeting was February 27th, next meeting on March 26th.
Attendees
- Julian Eisel
- Pablo Vazquez
- Hans Goudey
- Sean Kim
- Harley Acheson
Merged Since Last Meeting
- UI: Changes to Props Dialogs #118640
- UI: Change UI Name of Outliner “Orphan Data” mode to “Unused Data” #118758
- UI: Manage Unused Data Operator #118435
- Refactor: UI_BTYPE_SEPR_LINE Without Need for uiBut->a1 #118969
- UI: Add Title to Extensions Repo Popover #119009
- Refactor: ui_draw_popover_back Impossible Null Dereference #119092
- Fix #118765: Show Startup Popup Warning on Main Window #119096
- UI: Props Dialog Default Properties #119007
- UI: Improvements to Confirmation of Load Factory #117153
- UI: Improvements to Confirmation of Save Startup #117152
- UI: Improvements to Confirmation of Load Factory Preferences #117151
- Fix #116339: “Show Hidden Objects” operator’s options missing #119153
- UI: Allow Some Buttons to Scale Width With Text Style #119223
- UI: Adjust template_ID Buttons Width For Content Length #119229
- UI: Positioning of 3DView Sidebar Tab Titles #119231
- UI: Position of Current Frame Indicator Text #119236
- UI: template_ID button Width Minimums #119330
- WM: Add dynamic callback version of operator “depends on cursor” flag #118983
- UI: Allow copy & paste images in linux/Wayland #119117
High Priority Bug Reports
- Toggle Maximize Area loses state of expanded/collapsed asset catalogs #117957
- Now considered an important feature request
- Blender crash on pose library N-panel #108078
- A fix has been submitted
Go/No Go
- UI: Changes to Small Operator Confirmations #118346
- Without icon. Case issue with “Create new directory”
- Will review individual confirmations after merge, next Tuesday
- UI: Splash Screen Import Changes #118224
- Close, but small changes needed. Harley & Pablo will make/approve final changes.
Discussion
- UX: Polyline Gesture #119353
- We love it.
- Shift Extrude and Duplicate of meshes and objects #118968
- 4.2 Icon Changes #118734
- We want almost all listed changes. Try a different refresh with single arrow.
- Outliner on “Blender File” display mode to show use count + fake user column #118655
- UI Experiment: Color Tooltips #117815
- WIP: UI: Preferences Search #119072
- Working a bit, needs lots of work. UI issues to consider with highlighting categories, etc
- UI: Changes to Extensions UI #27
- WIP: UI: Image Editor Interactive Zoom Control #117050
- Harley not sure about Compositor?
- UI: Screen Area Docking #104665
Tests and Experiments
- UI Experiment: IDSearch Image Thumbnail Tooltips #118945
- We like a lot. Should have text info as well, including path. Pablo to consider.
- UI Experiment: Image Sequence Collapse #119193
- Interesting. Might work if this is another filter level, so open/close sequence.
- UI Experiment: Undo History Timestamps #118884
