User Interface Module Meeting 2024-03-26T16:00:00Z
Regular User Interface module meeting for planning and coordination. Last meeting was March 12th, next meeting on April 9th.
Attendees
- Julian Eisel
- Hans Goudey
- Harley Acheson
Merged Since Last Meeting
- UI: Changes to Small Operator Confirmations #118346
- UI: Add “Internet” Icon #119186
- UI: Use New Internet Icon #119409
- UI: Some Icons Resized #119425
- UI: Position of Tooltips for Labels #117879
- Fix #118066: File Browser List View Tooltips #118071
- Fix #119271: Update stats when switched between workspaces #119418
- UI: User Prefs Language Section #119430
- Fix #119183: Use valid style for popup text size calculation #119442
- UI: Correct Splash RGB Image Corner Rounding #119473
- UI: Timeline Playback Popup Too Narrow #119474
- UI: No Default Icon for Small Python Confirmations #119489
- UI: Improved Operator to Delete Custom Themes #118775
- UI: Improved Operator to Delete Custom Keyconfigs #118778
- UI: Small Confirmation Position #119536
- UI: Use Internet Icon for Repo Add menu #119541
- UI: Option for Separate Extension Dev Tools #119562
- UI: Update Polls on Single Repository Sync and Upgrade #119568
- Fix #119778: Crash in popovers that do not support refreshing #119796
- Fix #119203: fix SpaceMouse (NDOF) Deadzone value #119522
- UI: Add Optional Flags for Tooltip Image Fields #119437
- BLF: optimizations and fixes to font shader #119653
- Fix #119635: File Browser Horizontal Display Never Compact #119673
- Fix #119384: Outliner Edit Mode Toggle When Data is Shared #119704
- UI: Support layout panels in dialog popups #119519
- UI: Correction to Weight of 3D Viewport Overlay Text #119808
- UI: Updated Interface Font to Inter Version 4.0 #119720
- UI: Adjustments to Minimum Area Sizes #119848
Review
- UI: Splash Screen Import Changes #118224
- Requires sign-off by Pablo.
- Revert File Confirmation:
- UI: Changes to Confirmation When Reverting Current File #119542
- UI: Improvements to Revert File Operator Confirmation Popup #119758
- We prefer Jonas’ text, but will ask for a change to warning icon just to keep it consistent with other similar confirmations. We might want to circle back later and assign rules to when each icon is used. Harley will close his PR in favor of Jonas’ to encourage community contributions.
- UI: Outliner “File Mode” Manage User Count #118691
- We all prefer a one-column solution so that we can use them consistently elsewhere where we don’t have the extra space. Using “empty shield” and “full shield” to indicate the addition of fake user isn’t ideal when real users are also involved but is good enough. Possibly not enough differentiating between items that have no users from ones that have multiple real users but no fake user. And when items have multiple users it can look like we are counting shields. So we have a good indication of “protection” but miss a connection to “users”. But #118691 is probably as best as we’ll get for now.
Discussion
- Discussion of Roadmap items, mostly marveling at Julian’s TreeView sizing/scrolling changes.
- WIP: Shift Extrude and Duplicate of meshes and objects #118968
- We’ll try to arrange a joint meeting with the Modeling module to see how best to deal with modeling-related requests. Maybe having a meeting at Campbell’s start of day would allow Hans, Harley, and any North American module members to attend.
- UI: Blinking Text Cursors #116595
- We still like this and will try to make it a target for 4.2. Needs a check by Pablo (colors, opacity, blink speed, etc) then it needs a code review.
- UI: Screen Area Docking #104665
- Harley reminded module members to please try this.
- UI: Theme Color Tooltips #117815
- UI: Button to Save Custom Themes #119491
- Harley concerned that we might not be able to add the same for keymaps. It was decided that it was okay if that is the case. Harley will post a PR for “keymap save” so it can demonstrate why it would function in unexpected ways there.
- We also discussed the Extensions UI and all prefer the already agreed-upon format.
Confirmations Always On
- OBJECT_OT_simulation_nodes_cache_bake (when existing bake data) - "Overwrite existing bake data
- FILE_OT_delete - “Delete selected files”
- TEXT_OT_unlink - “Delete active text file”
- These are all important enough that we should just leave them alone for now.
Keymap Configurable Confirmations
- MARKER_OT_delete - “Delete selected markers”
- ANIM_OT_keyframe_delete_v3d - “Delete keyframes from selected objects”
- ANIM_OT_keyframe_clear_v3d - “Remove animation from selected objects”
- ARMATURE_OT_delete - “Delete selected bones”
- MASK_OT_delete - “Delete selected control points and splines”
- MBALL_OT_delete_metaelems - “Delete selected metaball elements”
- OBJECT_OT_delete - “Delete selected objects”
- ACTION_OT_delete - “Delete selected keyframes”
- CLIP_OT_graph_delete_curve - “Delete track corresponding to the selected curve”
- CLIP_OT_delete_track - “Delete selected tracks”
- CLIP_OT_delete_marker - “Delete marker for current frame from selected tracks”
- GRAPH_OT_delete - “Delete selected keyframes”
- The delete confirmations have added benefit when objects are out of view - accidentally deleting something unseen. Having the ability to know if unseen items are selected could let us change these to only warn in that case. This could be a nice future investigation. How quickly and easily can we tell if at least one selected item is out of view?
Non-delete confirmations to keep
- TEXT_OT_reload - “Reload active text file”
- Keep for now. There are times when these are shared and user counted.
Non-delete confirmations to remove
- ARMATURE_OT_separate - “Move selected bones to a separate armature”
- CURVE_OT_separate - “Move selected points to a new object”
- OBJECT_OT_vertex_parent_set - “Parent selected objects to the selected vertices”
- OBJECT_OT_parent_no_inverse_set - “Make Parent without inverse correction”
- FILE_OT_directory_new - “Create New Directory”
- We decided that the above are all explicit operations that have easy recovery. Make a new directory by accident? Just delete it. Others can be undone easily or have very clear invocation - hard to do by accident.
Confirmations still to be decided
- GRAPH_OT_keys_to_samples - “Convert selected keys to samples”
- NLA_OT_make_single_user - “Make each action single-user in the selects strips”
- For these two we will ask the Animation module to discuss and decide.
Experiments & Tests
- UI Experiment: IDSearch Image Thumbnail Tooltips #118945
- Collectively we like this idea, as long as the time taken to create the preview is quite short. Maybe we could have larger samples of materials this way and then remove the 32x32 samples which can be problematic when they are created. Having larger previews but only on demand make sense. This particular implementation is messier and noisier than it looks it should be. We can’t just keep adding more code like this to the tooltip area, needs some thought.
- UI Experiment: Maximize → Fullscreen. With Properties. #119850
- UI Experiment: Undo History Timestamps #118884
