The meeting will be on Tuesday 2023-05-16T10:00:00Z. It is open for everybody interested to join on Google Meet (link below).
Present: Armin Halac, Corrado Piscitelli Ivan Cappiello, MohammadHossein Jamshidi, Nate Rupsis, Nathan Vegdahl, Nitin Rawat, Sybren Stüvel
Links
- Google Meet. Note that there are no recordings of the meeting. This way everybody is free to say or show anything.
- A&R Module Meetings agenda for inclusion in your own calendar
- Previous meeting notes
- Issues & Pull Requests
- New face: Corrado Piscitelli, regular of Grease Pencil meetings. He has been TD for some animated features, colleague of Ivan.
- Last Monday the Blender manual and its translations migrated from Subversion to Git.
Nate points at the Relative Ease add-on.
- Nate might be able to reach out and explain the ‘copyrighted material’ issue.
Landed
51c2a0f81606: Fix #104606: iTaSC solver moves root bone to origin and imobilizes it
- Added new option to the iTaSC solver armature properties.
aaf56d7aa552: Refactor: Anim, Symmetrize Armature operator
- Preparation for improving the ‘Symmetrize Armature’ operator
Armin working on a bug report, where constraints are removed from the
+X
side.
- #107672: UI: Changes to NLA Solo Button
Short-term goals / Ongoing Work
#107653: Paint: Add loop select for faces
- Under review by Hans Goudey.
- #102662: NLA-Strip Corrupted after opening file again in case of library override
- #106801: Rigify + NLA - assigned action is lost if file is saved while in tweaking mode on rigify generated linked rig
- #106952: Animation: Butterworth Smoothing filter
Powership
- Lukas Tönne is working on #105491: Expandable component sockets
- Sybren added comment with some of our ideas/needs/desires
Patch Review & Decision Time
#107691: Rename Copy Vertex Group to Duplicate Vertex Group
- Module agrees, good clarification.
- MHJ: operator name should change as well.
- Sybren: not worth the effort on others.
- Nate: should the description change?
- Sybren: explain where the copy is going?
- Not blocking though, and this is already an improvement.
#76791: Different results when keyframing visual transforms and applying transforms manually on IK constraint
- To decide: address in 4.0, or close as ‘will not fix’?
- Nathan: fix it, as the current behaviour is not “what’s on the tin”.
- Module decides: should be fixed for 4.0.
PowerShip progress demo
Sybren demonstrated his progress with Powership.
Nathan shows data model ideas
Same presentation as two weeks ago (slides).
- With some extra insight from yesterday’s discussions with Bastien Montagne and Sybren.
- Also mentioning the ‘performance prototype’ he’s been working on, which shows promising results.
Next Meeting
The next meeting will be on Thursday 2023-05-25T16:00:00Z. Again it will be open for everybody who’s interested. The provisionary meeting agenda will be linked in the #animation-module channel before the meeting.
