2 October 2023
Announcements
- Blender 4.1 development started and Blender 4.0 is in beta now.
- Weizhen is on a planned break from Blender development for the next 6 months.
Modules & Projects
- VFX & Video meeting notes 2023-09-26
- 2023-09-28 Animation & Rigging module meeting
- 2023-09-29 Layered Animation model & Grease Pencil v3
- 2023-10-02 EEVEE/Viewport Module Meeting
New Features and Changes
Animation
- Warn when a bone is added to a hidden bone collection (commit) (Sybren A. StĂŒvel)
- Change UI label from âEdit Bone Colorâ to just âBone Colorâ (commit) (Sybren A. StĂŒvel)
- Add âmove bone to collectionâ operator to pose mode menu (commit) (Sybren A. StĂŒvel)
- Add channel type options to the Bake Action operator (commit) (Nate Rupsis)
- Keymap
- Replace âshow all layersâ with âshow all collectionsâ (commit) (Sybren A. StĂŒvel)
- Rename the âSkeletonâ panel to âPoseâ (commit) (Sybren A. StĂŒvel)
- Add overview of bone collections to bone property panel (commit) (Sybren A. StĂŒvel)
- Move âsolo bone collectionâ operator to menu and add âshow allâ (commit) (Sybren A. StĂŒvel)
- Implement a new curve-aware vertex to B-Bone segment mapping mode (commit) (Alexander Gavrilov)
- Improve readability of channel colors in channel list (commit) (Sybren A. StĂŒvel)
- Add operator to âsoloâ the active bone collection (commit) (Sybren A. StĂŒvel)
- Add operator to sync bone colors between selected bones (commit) (Sybren A. StĂŒvel)
- Bone color properties panel layout tweaks (commit) (Sybren A. StĂŒvel)
User Interface
- Draw asset shelf, image editor, and 3D view tools header transparent with button backgrounds (commit, commit, commit) (Julian Eisel)
- Change snap icons (commit) (Germano Cavalcante)
- Keymap
- Node Editor
- Match Node Editor Node menu with Context menu (commit) (Pablo Vazquez)
- Anchor right when double-clicking last word (commit) (Harley Acheson)
- Show waiting mouse cursor while file loading (commit, commit) (Harley Acheson)
- Allow separate configuration of subpixel antialiasing (commit) (Harley Acheson)
- Move Bone Wireframe Opacity to general overlays (commit) (Pablo Vazquez)
- Change Overlay Text Size with Label Text Style (commit) (Harley Acheson)
- Remove Masking dropdown from tool settings (commit) (Pablo Vazquez)
- Remove âModesâ label in animation editors (commit) (Nate Rupsis)
- Remove redundant âContext Menuâ in menu titles (commit) (Pablo Vazquez)
- Move âReset Recentâ inside a menu (commit) (persun)
- Splash & About menus
- Remove duplicate Make Library Override in Object menu (commit) (Pablo Vazquez)
- Search
- Asset shelf
Geometry Nodes
- Node tools
- Require modifier tag for add menu, show non-assets (commit) (Hans Goudey)
- Support baking individual simulations (commit) (Jacques Lucke)
- Add utility to check for bad geometry element index dependence (commit, commit) (Jacques Lucke)
- Add Inspection Index to Repeat Zone (commit) (Jacques Lucke)
Realtime Compositor
- Use Int2 images in JFA algorithm (commit) (Omar Emara)
Video Sequence Editor
- Improve retiming UI (commit) (Richard Antalik)
EEVEE
- EEVEE-Next
- Add tracing options for diffuse rays (commit) (CleÌment Foucault)
- Shadow Map Tracing Initial Implementation (commit) (Clément Foucault)
- Object visibility settings for probes (commit) (Miguel Pozo)
- Irradiance Grid clip distance and probe alignment (commit) (Miguel Pozo)
- Port subsurface to compute shader (commit) (Clément Foucault)
- Otimize principled BSDF by skipping unused components (commit) (Brecht Van Lommel)
- Add support for metallic F82 tint (commit) (CleÌment Foucault)
Curve
- Adjust behavior of invert selection for bezier handlers (commit) (Campbell Barton)
Mesh
- Show attribute name collision warning in more panels (commit) (Jacques Lucke)
Shader Nodes
- Adjust names and organization of Principled BSDF inputs (commit, commit, commit, commit, commit) (Brecht Van Lommel)
- Clamp various shader inputs for Principled BSDF (commit) (Alaska)
- Change Specular input on Principled BSDF to affect IOR (commit) (Lukas Stockner)
- Use single Principled BSDF input for metallic and specular tint (commit) (Brecht Van Lommel)
- Change specular tint in Principled BSDF from float to color (commit) (Weizhen Huang)
Cycles
- Add Metallic Tint to Principled BSDF using F82-Tint model (commit) (Lukas Stockner)
- Light Linking
- Metal
- Throttle MetalRT BVH builds to avoid exceeding working set limits (commit) (Michael Jones)
- oneAPI
- Fix performance regression by inlining svm_node_closure_bsdf (commit) (Xavier Hallade)
Import/Export
- USD
- Improve I/O of emission color in preview surface (commit) (Brecht Van Lommel)
- Hydra
- Export Blender shader nodes as MaterialX node graph (commit) (Bogdan Nagirniak)
Python API
- Add specular tint texture support to node_shader_utils (commit) (Brecht Van Lommel)
- Add
full_pathattribute toAssetRepresentation(commit) (Colin Basnett)
