10 October 2022
Announcements
- Blender LTS update: Blender 3.3.1 LTS brings 74 fixes since its initial release, while Blender 2.93.11 LTS addresses 13.
Modules & Projects
- 2022-10-4 Sculpt/Texture/Paint Module Meeting
- 2022-10-04 Render & Cycles Meeting
- 2022-10-05 Geometry Nodes sub-module meeting
- 2022-10-06 Pipeline, Assets & I/O Meeting
- 2022-10-10 Eevee/Viewport Module Meeting
New Features and Changes
Animation
- Expose “mute” for drivers in their properties UI (commit) (Sybren A. Stüvel)
- Armature modifier: Skip non-deforming vertices in Multi-Modifier mode. (commit) (Alexander Gavrilov)
- Update tooltips to be more readable (commit) (James)
Curve
- Increase max of NURBS order U/V (commit) (Campbell Barton)
- Retain active curve after point deletion (commit) (Laurynas Duburas)
Mesh
- Multithread some boolean domain interpolation logic (commit) (Iliya Katueshenock)
- Skip some domain interpolations for single values (commit) (Iliya Katueshenock)
Render
- Access geometry node instance attributes. (commit) (Alexander Gavrilov)
- Support accessing attributes of View Layer and Scene. (commit) (Alexander Gavrilov)
Grease Pencil
- Allow adjusting fill tool extend lines with tablet middle mouse button (commit) (Antonio Vazquez)
- New modifier icons for Envelope and Outline modifiers (commit, commit) (Antonio Vazquez)
Sculpt
- Raise PBVH leaf size limit to 400 for dyntopo (commit) (Joseph Eagar)
Geometry Nodes
- New Sample UV Surface node (commit) (Jacques Lucke)
- New Set Curve Normal node (commit, commit) (Johnny Matthews)
- Add soft min for points node radius input (commit) (Hans Goudey)
- Rename Control Point Neighbors Node (commit) (Hans Goudey)
- Change order of outputs in topology nodes (commit) (Hans Goudey)
Cycles
- Add option to bake specular from active camera viewpoint (commit) (Phoenix Katsch)
- Slightly improve performance for oneAPI backend (commit) (Nikita Sirgienko)
Import/Export
- Support Presets in Alembic, Collada, OBJ, STL, USD importers (commit) (Aras Pranckevicius)
- OBJ
- Add global scale factor import setting (commit) (Aras Pranckevicius)
Viewport
- Split ViewProjectionMatrix in order to increase precision (commit) (Clément Foucault)
Linux/Wayland
- Enable WAYLAND by default (commit) (Campbell Barton)
- Show the windowing environment in the “About” splash (commit) (Campbell Barton)
Miscellaneous
- Vector Math: Unroll vector loops for better performance on GCC (commit) (Hans Goudey)
- Images
- Translation
- Preferences
- Support loading factory settings only for app-templates (commit) (Campbell Barton)
