10 March 2025
10 March 2025
Announcements
Modules & Projects
New Features and Changes
Assets
  • Batch create/remove previews for all selected assets (commit) - (Julian Eisel)
Compositor
  • Track update count for cache invalidation (commit) - (Omar Emara)
Core
  • RNA: Use VectorSet for StructRNA properties lookup (commit) - (Guillermo Venegas)
Curves
  • Fix bounding box ignores radius, add option to geometry node (commit) - (Hans Goudey)
Cycles
  • Adjust inlining attributes for oneAPI device (commit) - (Xavier Hallade)
  • Split OSLManager out of OSLShaderManager (commit) - (Lukas Stockner)
  • Enable HIP-RT logging when debug log is on (commit) - (Sergey Sharybin)
  • oneAPI:
    • Enable automated GRF mode selection (commit) - (Xavier Hallade)
    • Force normal GRF for integrator_intersect_* kernels (commit) - (Xavier Hallade)
DRW
  • Make DRWContext thread local (commit) - (ClĂ©ment Foucault)
  • Use depsgraph update count to replace view_update (commit) - (ClĂ©ment Foucault)
Depth Picking
  • Do not include non-selectable object in depth picking (commit) - (ClĂ©ment Foucault)
GPU
  • Remove RDNA2 shader viewport workaround (commit) - (Jeroen Bakker)
Geometry
  • Support “Convert Attribute” for curves and point cloud (commit) - (Hans Goudey)
Geometry Nodes
  • Add “Face” option to Mesh to Curve node (commit) - (Hans Goudey)
  • Support custom delimiter in Import CSV node (commit) - (Jacques Lucke)
  • Support opening images in modifier (commit) - (Jacques Lucke)
  • Import Text node (commit) - (Hans Goudey)
  • Add names to String to Curves instance geometries (commit) - (Hans Goudey)
  • Avoid logging entire long strings (commit) - (Hans Goudey)
I/O
  • Smoothgroups: Add option to also consider ‘sharp vertices’. (commit) - (Bastien Montagne)
Nodes
  • Implement operator node.activate_viewer() (commit) - (Habib Gahbiche)
Overlay
  • Add DepthOnly GPU debug capture scope (commit) - (ClĂ©ment Foucault)
Screen
  • Support garbage collection of layout panel states (commit) - (Jacques Lucke)
Sculpt
  • Add Mask by Color to menu bar and enable redo panel (commit) - (Sean Kim)
Shading
  • Retain alpha in Mix Color shader code (commit) - (Omar Emara)
SubDiv
  • Migrate GPU subdivision to use GPU module (commit) - (Jeroen Bakker)
UI
  • Collections: Rename & update Restrictions panel for consistency (commit) - (Quentin)
  • Update curves edit mode menus (commit) - (Mattias Fredriksson)
  • Show “Not Found” Icon when Not Found (commit) - (Harley Acheson)
  • Add Specific Icon to Represent Preview While Loading (commit) - (Harley Acheson)
  • Show ‘+ New’ button in Action Slot selector when no slot is selected (commit) - (Sybren A. StĂŒvel)
  • Always show cage 2D rotation handle if rotation is enabled (commit) - (Habib Gahbiche)
VSE
  • Report one-time property changes (commit) - (John Kiril Swenson)
Vulkan
  • Enable vk loader logging (commit) - (Jeroen Bakker)
Weekly Reports
This topic was automatically closed 365 days after the last reply. New replies are no longer allowed.
