Attendees
- Brecht Van Lommel (Blender)
- Lukas Stockner (Blender)
- Nikita Sirgienko (Intel)
- Michael Jones (Apple)
- Patrick Mours (NVIDIA)
- Sahar A. Kashi (AMD)
- Sergey Sharybin (Blender)
- Stefan Werner (Intel)
- Thomas Dinges (Blender)
- Weizhen Huang (Blender)
- Xavier Hallade
Notes
- For Blender 4.4
- High priority:
- HIP SDK public availability: it is a priority for the release
- HIP / HIP-RT render if Blender executable has space in path:
- Worked around for the Blender 4.4 release.
- Only done for
bvh_build_array.h
. oro_compiled_kernels.h
could have the same issue. The issue did not manifest itself (possibly due to the data being much smaller than thebvh_build_array.h
).- From the meeting: ORO is for low quality BVH, not used in default code-path. So need to double-check the behavior.
- Only done for
- Remaining issue is OIDN on HIP, but it also did not work in such configuration in Blender 4.3.
- Root cause: somehow
hipModuleLoadData()
errors out when a big buffer global buffer is passed to it.
- Other
- Brecht filled in the project details of texture cache and mipmaps
- Hopefully can start working on it ASAP.
- Brecht keeps working on adaptive subdivison and volume fixes.
- Weizhen implements volume scattering probability guiding framework.
- Denoising for variance estimation.
- It can be hooked up to the current render work, but need a bit of work to hook up all the pieces together.
- Lukas keeps working on OSL nodes for custom camera. The PR should be ready, running CI/CD as we speak.
- Lukas plans finish all PR that are in-flight, work on FMX presentation, then come back to principled BSDF.
- Nikita: Intel is looking into looks OIDN DLL loading issue.
- Nikita: Node link drawing issue looking into this, could be fixed on Blender side. Nikita considers it a priority. We might be able to fix it from Blender side for 4.4, but would be good if it is fixed in driver to make older releases work.
- HIP-RT: Fix remaining issues (especially crash) and make official.
- Even enable by default
- Nikita: need to find solution to communicate situation when there are 2 GPUs with different driver version requirement.
Practical Info
This is a weekly video chat meeting for planning and discussion of Blender rendering development. Any contributor (developer, UI/UX designer, writer, …) working on rendering in Blender is welcome to join and add proposed items to the agenda.
- Google Meet
- Google Calendar Event
- Next Meeting: March 18 2025, 3 to 4 PM Amsterdam Time (Your local time: 2025-03-18T14:00:00Z)
