Something I noticed on the VSE is that I can’t scroll vertically to see more channels than initially appear on a normal split window.
I can see about 8-9 channels but if I want to reach channel 50, I can’t just scroll vertically as the scrolling is clamped to the scope of the channels that contain strips.
A workaround is obviously to put a placeholder strip on channel 50 so I can get more range, but it leaves too much empty space for nothing.
(As a sidenote, to put a strip on channel 50 you have to move it upwards without seeing anything… not very convenient!)
Is there a way to bypass that clamping and be able to scroll at will with no limitation?
(the same way you can scroll as much as you want horizontally)
