Hello everyone, congrats on the 2.93 release.
In a new scene, strictly used for compositing with an external image sequence, I get a double sequence output, and I don’t understand why.
The scene has:
- no render layers node
- no composite node
- the view layer is disabled for rendering
With those settings, I don’t understand why the render animation button is exporting a blank sequence, using the output properties tab - output settings:
So what I do is clear the output path of the output properties, to avoid exporting the double sequence.
Is that the correct workflow?
