In an effort to better understand the color differences between Spectral and regular Cycles as it stands right now, I repeated the Suzanne In A Box experiments with the latest version and also created Diffs for all of them.
All of these images use the Standard view transform rather than Filmic to make them more comparable. Using Filmic would make them look better in principle though.
Additionally, I had a look at various render layers and as has been noted before, there are pretty large discrepancies in some of them.
In the following, there are two versions (RGB and Spectral) plus their difference in six variants corresponding to either the ceiling lighting, the side-walls, or the Suzannes being either red, green, or blue.
So entirely expectedly, there are differences in all three channels of course.
And looking at, for instance, the three rightmost Suzannes in the top row of the first set (there are many more examples) it also seems clear that a lot of the differences are, in particular, in the indirect lighting, which is also expected.
However, comparing all the diffs, it seems to me it’s pretty clear that the biggest differences, even in very varied situations, tend to be in the red channel.
It would be great to compare specifically the difference as it appears in direct vs. indirect light for both diffuse and specular rays. Unfortunately, those channels appear to currently be broken in the spectral branch. Here, just one example, for the sixth set (which seems to have the lowest difference of them all)
As you can see, the Diffuse and Glossy base colors are pretty close in each. In fact the two glossy ones are identical. Though the difference of Diffuse Colors reveals that there is quite significantly more red in the spectral version, as well as a slight difference in blue.
And all the Direct/Indirect light passes in Spectral are completely wrong. They lack color, and the top row of Diffuse Indirect Lighting, as well as the leftmost wall, just completely break. - It looks like high saturation colors aren’t quite correctly normalized right now.
(Note, for the most saturated portions, I set one channel for each of these colors except for the emitter to 0.9 and the other two to 0.001 in order to avoid what might be tiny rounding errors when it comes to values close to 0 or 1. So I don’t think this is an issue of exploding wavelengths or ones that go negative or something like that.)
What an awesome comprehensive test! It’s great to see that the Spectral one consistently shows more retained brightness in saturated indirect light. It makes sense that there’s the most difference where at least one aspect (light or material) is quite saturated.
It’s clear that the passes are completely jumbled up right now. Not sure what’s going on there since I believe I mapped everything to what it was supposed to be mapped to, but I’m sure I’ve just made a silly mistake somewhere in the code responsible for populating the passes.
I’m encouraged that there seems to be very little difference in noise performance, both luminance and colour noise seem indistinguishable from each other (permitting differences due to significantly varied light levels).
Noise isn’t quite identical, but yeah it’s very close. Almost surprisingly so, even.
The fireflies are in different spots (using the same seed) and I think (though this is relatively anecdotal) spectral rendering actually performs slightly better in that regard. It appears as if there are fewer noticeable hotspots. To be fair, though, this scene generally produces very few of those in general, and so it might well be pretty much random and about equal in that regard.
Yep, the noise pattern should be similar but maybe marginally different in some cases. I would expect fireflies which have a relatively neutral colour to resolve at least as quickly as RGB cycles, but very narrow spectra (without making use of the custom wavelength importance) will likely result in somewhat more noise than RGB. Much more thorough and quantitative testing would have to be done to properly compare noise performance. For example, the RMS of the difference between a ground truth render and a noisy render might be a decent starting point.
I’m not sure that’s even entirely fair. RGB can’t even distinguish between narrow and wide spectra in the first place. how would you even compare?
I guess the closest you could get to is to light your entire scene with spectra that are as narrow as possible but approximate sRGB? (Which would be weird in that sRGB inherently doesn’t correspond to monochromatic light sources)
I think the current heuristic of going “if we can see it more, it’s more relevant” is a good one for 99% of scenes at least. If your scene really needs to rely on a crazy narrow spectrum to sample from (perhaps because you are simulating laser light or something), I’d guess the way to go there is to actually change the sampling spectrum as is already possible.
That’s a great point. We can only compare them in cases where there’s a meaningful comparison to make. Scenes built with spectral in mind from the start might come with some more subjective benefits which are hard to quantify.
Fixing up the passes is my next task. Thanks again for the updated test.
Perhaps stating the obvious but it would probably be good to start accumulating a real render test suite in the same vain as what already exists for cycles/eevee sooner rather than later (for instance there’s tests for those engines that check the various passes). Almost certain that spectral would not be accepted as a contribution, being so large and fundamental, without the corresponding set of tests to continuously verify it.
The current suite is large, but very bland (in amount of color and light used). Would probably still have to follow it’s lead (in spirit at least) and create similar tests. Spectral changes I think would still be apparent with a similar light, color, sample count setup as the existing tests.
Certainly the current suite could essentially be reused and then added to. I think the 25 Suzannes scene I used above is a good candidate for that. Although it could probably be made to render faster.
And if the old suite is reused, currently it’d sound the alarm “THERE ARE DIFFERENCES HERE!” when, for once, that is entirely intended. It’s tricky to suss out which part of the change is spectral effects and which part may be actual bugs. - I still think there is something slightly iffy with the red channel at least. It just consistently has the largest errors (in that the differences in that channel compared with regular Cycles are the largest)
But anyway, yes, I concur: A solid rendering test suite for establishing the ground truth would be excellent. In fact it’d probably be worth it to go through every single issue or potential issue found in this thread thus far and make at least one test scene for that specific issue.
Oh for sure it wouldn’t be for comparisons with the existing set of checked in images, you would have a completely new set of images used for comparisons. What I mean by “follow what’s there currently” is to roughly use the same set of scenes and setups (or equivalent) to ensure spectral is doing the right thing in similar situations.
It’s not to ensure it matches with rgb in most situations, it’s to ensure that when you make spectral changes it doesn’t break pre-existing spectral results as well as forcing you to consider things like render passes etc.
And yeah, the existing tests use such small resolution, samples, geometry because they need to execute really quickly. The larger tests are better suited as “demo” or “benchmark” scenes.
Would it make sense to reuse those scenes in a test with other spectral engines out there?
I’d like to see what Luxcore outputs with those 25 suzanne setups, for example.
That would be interesting to see indeed. IIRC LuxCore actually isn’t spectral anymore, they moved away from being a spectral render engine when they renamed it to LuxCore, but if there are any other spectral engines out there that people have access to, I’d love to see the results.
I could probably change the scene to be better for that. As it stands, the way I did the materials doesn’t quite work for this though.
One thing I did was to add a plane in front of the boxes, which is invisible to the camera. These are actually closed rooms! And removing that plane makes a big difference in the appearance, since a lot less light would be reflected back. A lot of it would escape into the black void on the outside.
In Cycles, accomplishing this is very easy (just make it transparent if your ray is a camera ray) but I’m not sure how capable of that other renderers are.
I haven’t super looked into this yet but in principle I should be able to get it to work on Mitsuba 2, right?
I wish there was a ready version I could just simply use for rendering straightforwardly rather than having to build it myself tho.
Also on LuxCore, first google result yielded this forum thread Spectral rendering - LuxCoreRender Forums
Turns out we are being watched hi there, lurking LuxCore folks!
The very first concern is increased render time. On that note, Spectral rendering is indeed slower than regular Cycles. And there are two separate effects there, I think.
It takes slightly more computations to process any given ray (although this seems to be rather minor)
in particular highly saturated, dark colors are often already dropped in regular Cycles, deemed minimally impactful to the render result. BUT Spectrally there may actually be quite a lot of remaining energy. So the cutoff tends to happen later.
I think the biggest time impact will be from that. It’s slower to render such scenes, literally because there is more visual detail. So that extra rendertime goes to good use.
This effect is very noticeable in this Suzannes scene: I set the render pattern from Right to Left so it’d start with the least saturated part and go to the most saturated part.
Regular Cycles speeds up quite solidly as it reaches the left edge.
And Spectral Cycles also speeds up. But not by as much. Simply because there is more indirect light to go around (and still appreciably impact the scene - this is, after all, the exact situation where the differences are gonna be the greatest)
Meanwhile the noise concerns seem to be very much addressed by the Hero Wavelength algorithm that’s at work here. It’s clear from the Suzanne test (btw I rendered at 1024 samples and deliberately did not use denoise - I even turned off the post-processing dithering that’s there by default to get maximum comparability) that the noise ends up being about the same.
Hi kram1032, I recently read Veach’s dissertation “Robust Monte Carlo Methods for Light Transport Simulation” where (amongst others) chapter 5.2 page 143 and chapter 6.2 mentions that light changes wavelength when crossing a dielectric interface and how to compensate the BSDFs for this effect. Also, Veach mentions in chapter 4.5 page 115 footnote 10 that spectral sampling should happen in frequency-space, rather than wavelength space. Could this explain the too-red issue?
I don’t think that should matter: Those are effects that would be false in a tricolor renderer as well as in a spectral renderer if neither of them compensates for this. I’d think they’d be false in the same way.
The example concerning BSDFs isn’t related to sampling specific wavelengths as far as I can tell, but rather about the material definitions. Changes to that would have to be made at a different point than what the current Spectral Renderer project does. (It may become relevant later, once new BSDFs are making use of the spectral data, such as for Complex IOR materials)
Also, this is from 1997. I suspect the state of the art has changed a lot since then. (For one, wavelength sampling is done through the hero wavelength algorithm which is much newer. AFAIK it has guarantees to converge to the right result)
I’m not sure why these scenes are so different though. My guess is, that this is mostly due to the light source. Presumably that’s a blackbody emitter which obviously could look quite differently spectrally. But in case that isn’t what’s going on here, it’s an interesting difference.
FWIW the spectral version looks more natural to me.
Still gotta figure out how to actually build it.
Status update: I have a new computer which is capable of running 2.8+ at acceptable frame rates now thanks to CrowdRender, I’ve just set blender development up on it and I’ve got the spectral branch compiling again.
I’m looking for a test scene which I would be able to use to make comparisons between Spectral and RGB cycles, ideally something non-trivial, maybe an existing scene could work. Scenes with heavy use of coloured lights could be a good fit to make the differences easier to see, and it would be good to have a variety of materials and light paths visible. If anyone knows of a scene which is free to use or has one of their own they’d like to propose please let me know. I saw this scene used in a gamut mapping discussion over at ACES which I feel does a good enough job but considering the goal here is evaluating the light transport (rather than just gamut mapping) a slightly more complex scene might work better.
I’m happy to help too! Would you prefer something with multiple geometric opaque and transparent shapes? With various indexes of refraction? With various BSDFs? With some shapes having volume absorption and/or volume scattering? Sky texture/Nishita ? What aspect ratio would work best? How about depth-of-field? Polycount? Should the rendering converge fast or slow? As long as you don’t expect some fancy sculpted creature, I’d be happy to contribute/cocreate.
Thanks, the 25 suzannes does seem like a good render ‘integration test’ to have.
I was thinking I could modify a Blender example scene, definitely worth a try.
Yes to all of the above Ideally it would resolve relatively quickly but maybe still one area can test the noise performance by being much more difficult to render (only indirect light etc)
