Thoughts on making Cycles into a spectral renderer
Thanks @LazyDodo, for the wavelengh bound variables, I just replaced them with defines to get it to build since they’re only used in that 1 spot for now.
Seems to render fine on the GPU at about the speed I would expect!
2x GTX 1080: 3:29
Ryzen 9 3950x: 2:01
Combined: 1:25
Great to see you got that working. I’m really interested to see that colour chart in the RGB renderer to compare, along with the time differences, do you think you could make that some time @mmdanggg2?
in direct comparison the main diffference betweem those two renders appears to be a different whitepoint
hmm…
spectral cycles srgb gamma 2.2 vs rgb cycles with standard tonemapping
Webp.net-gifmaker
the one with brighter grays on the chart is spectral
EDIT: this is probably view transform difference rather than spectral rendering. Also currently saving render from spectral the output looks different than in blender image viewer.
here you can see difference between saved jpeg (cctf view transform) vs how it looks in blender
Interesting result. I wonder why that would be happening. Either way I don’t think it’s worth digging into just yet, there are plenty of areas of the system which are yet unfinished.
It appears that in my scenes, only when I go to super extreme colors I can see the difference.
In this case It looks identical to me…
RGB
Spectral
They are so close to being identical that I laughed :smile: Great demo.
It looks you are doing very good with this, congrats! :slight_smile:
I hope this ends up in master sooner than later, I imagine this could bring other benefits in other areas :slight_smile:
Just a question, I don’t really use Branched Pathtracing, does this support BPT or this only works with “normal” PT?
Also does this bring any benefits or ease to implement things like light tracing for fast caustics or other techniques, like GI cache?
Also, does this solve the problem @troy_s always mention about color management in Cycles?
Thanks!
Thanks, I appreciate it. It has been a long time coming but I’m happy to see some progress happening, although I can tell things are just getting started.
I hope the benefits are widespread, too.
It should, as in, there’s no reason it can’t, but honestly I haven’t tested it. If it’s broken, it is just a matter of me going and fixing the code!
EDIT: I checked, I’ve skipped it for now, once I have time to jump into BPT and understand how it works I’m hoping it’ll be a relatively straightforward change.
No, not that I can see. I’m not an expert on light transport algorithms, but I think that and spectral rendering are relatively separate domains. Instead of noisy white caustics, you can have noisy coloured caustics!
Colour management is a complex beast and I don’t think any one thing will ‘solve’ it, but I’ve been working with Troy on the OCIO side of this (which is a massive help) and I think there will be colour management benefits to come from this, especially in targeting modern (HDR, large gamut) outputs.
For pixel filters we have code like this in the kernel:
  int filter_table_offset = kernel_data.film.filter_table_offset;
  float raster_x = x + lookup_table_read(kg, filter_u, filter_table_offset, FILTER_TABLE_SIZE);
There we don’t compute any weight because it’s always 1.0, as the evaluated function and pdf cancel out. That’s ideal for importance sampling, and hopefully the same is possible here as well.
Otherwise, you would store the pdfs in a table as well and divide by them somewhere. I haven’t looked close enough at your code to see where the best place is.
That makes sense. Maybe I was misunderstanding what a PDF actually represents - it’s only the difference between the ideal distribution and the sampled distribution?
The use-case here is just to sample wavelengths weighted according to their perceived brightness, but the brightness of a wavelength is embedded in the CMFs, so I think I’ll need to come up with a curve to turn into both 1) the sampling weights and 2) something to divide by such that each wavelength’s overall contribution doesn’t change.
I’ll need to do a refresher on PDFs I guess, thanks for the tips.
@smilebags aren’t you doing hero-wavelength sampling? So sampling a hero-wavelength from a CMF or black-body-radiator or whatever wavelength distribution will also automatically return a sample at each of three other wavelengths (at fixed intervals?)… so the probability distribution gets convoluted (in a quite literally sense by the 4 Dirac spikes at those intervals) and thereby may lose significant noise reduction power. Then again… if the bandwidth of your Gaussian spectrum gets minimal, you get at least one sample for each 4 channels.
Yep
I’m not sure if I’m on the same page as you here.
My understanding of hero wavelength is that it is simply an approach of letting extra wavelengths ‘tag along for the ride’ on a base wavelength light calculation, since most of the time, most outgoing directions of a BxDF will have a non-zero throughput for a large part of the spectrum.
A bonus way of reducing noise when using hero wavelength is to correlate each of the wavelengths used such that the sum of their resulting XYZ locations doesn’t vary too much. This is done by evenly distributing the ‘child’ wavelengths over the wavelength dimension (0-1) of the integration problem.
What I’m doing after this is to skew the actual wavelengths sampled by this 0-1 range such that a majority of samples occur at wavelengths which have significant visual impact on the result, hence reducing noise.
I’m delegating the task of actually coming up with such a distribution to later, since there are all sorts of ways you could generate it, such as from the scene lights, a user-supplied curve etc.
This all happens completely unaware of any particular spectrum in the system (such as a gaussian spectrum) and narrow gaussian spectra are likely to be quite noisy until I can work on some more advanced sampling optimisations.
Brecht and Lukas have done quite a bit of work already to fix this in Cycles; Cycles was not colour managed! There are a couple of lingering issues, but last I looked, a majority were tidied up. It would be good if more people were versed in pixel management to be able to run it through tests to assert behaviour. Using rotated primaries is typically a very good way to test if management is working for example.
The other side of the coin is user interface, input, and output. For example:
  • Is the file encoding happening correctly and what transforms are applied?
  • Is the working reference model presented to the author properly?
  • Does an author have proper control over the input and output based on the current authorship context?
The above still are not addressed in Blender proper, and focused changes need to happen there as a high priority.
@smilebags, we are almost on the same page I think. You do in fact mention the way you are going to solve my doubts: “skew… such that a majority of samples” and “perceived brightness”. So no worries. It is just that I expect that such skewing is very complex and won’t add much unless: 1) the perceived spectrum already features four humps or 2) when the distance between ‘child’ wavelengths is much smaller than the full sampled wavelength range which could put more samples near wavelengths about pure/saturated colors. Delegation / postponing sounds fine for now.
I think this is where we differ in understanding.
Regardless of the number of wavelengths that end up hitting any particular spectrum, the more values that are sampled in wavelengths that contribute a lot to the scene (green, vs a dim, almost invisible far-blue) the less noise there will be. That’s the goal.
The RGB render
Definately much faster in the standard render, I build the latest master to rule out build differences with the prebuild downloads.
2x GTX 1080: 0:42
Ryzen 9 3950x: 1:15
Combined: 0:32
I believe it’s simply weighting sampling based on luminous efficacy, which isn’t terribly complex at all. If it is something else, then perhaps.
That’s quite a time difference! I’ll have to look where that’s coming from, I imagine it might be my terribly inefficient hacks since I don’t know the language and code well enough.
