Texture painting in material mode - where is the shaded view?
I like the new material mode in Texture painting, but it seems it changed somehow so I can’t view the shaded material at the same time as I’m doing painting on a texture in my paint slots. Is there a new way to do this? Splitting the window doesn’t work because all 3D windows will show the same view mode (ie object more, texture paint etc). :-/
do you mean
turning on and off overlays to see the texture or the result?
Look dev or workbench?
need to change to object mode back and forward because doesn’t update?
Is this what you are looking for?
@Mongpic Yes, that’s it! Thank you! Works perfectly with a split view too! Thank you! This is so great!
