I noticed this jumping when using MMB to constraint the movement in Local transform orientation.
To reproduce it create a cube, rotate it, grab it and use MMB to move and constraint the cube in some direction. After releasing the MMB the position of the cube changes.
This doesn’t happen when rotating or scaling. (or moving in Global l transform orientation)
Thanks, I reported it as a bug.
