This was a proposal by @Odin3D on right-click-select which makes a lot of sense to implement.
He suggests having ctrl+wheel up for select more and ctrl+wheel down for select less. I then suggested to also have ctrl+shift+wheel up for select next active and also ctrl+shift+wheel down for select previous active.
It really speeds up the workflow by not having you move the hand from the mouse to the keyboard.
