Remove the ''Remove from local view'' pop-up
#1
When removing an object from local view pressing M you get a pop-up asking to confirm the operation.
Is already possible to remove the pop-up, or maybe it should not be there at all. Seems like a very specific operation and doing it by mistake would not be a problem since undo works with it.
#2
M is not to remove the object from local view, you use H to hide the object and Alt + H to unhide.
M is to move the object between collections (kinda like layers or groups)
#3
#4
what? when was this?
#5
You have to press ‘’/’’ to go to local view.
#6
This shortcut only exists when you are “inside” the local view.
#7
I downloaded the latest version and its still there, M is for move to collection.
#8
See post above.
#9
OOhh, got it, I never tested local view actually, thats why.
