Can the Remove Double be moved from the spesial menu to the delete men
Yes, it could. But really it is more similar to Merge than Delete.
It also should probably be renamed to something like Distance Merge.
Remove Doubles is quite a poor name:
- ‘Remove’ is not right. It performs a merge.
- ‘Doubles’ is not right. It uses a distance, and merges anything within that distance threshold. Doubles implies exactly two things that are identical, even though it works with any number of vertices within the distance.
If we add Remove Doubles/Distance Merge to the Delete menu, we should also add Merge there, which starts to seem a bit odd.
