This is the copy from this issue: https://developer.blender.org/T86715
I noticed if I will use bpy_extras.mesh_utils.mesh_linked_uv_islands(mesh) it will not take into account 3d islands
It would be nice to have an option to separate 3d islands and UV shells too. You could add a variable in the method.
Something like mesh_linked_uv_islands(mesh, separate_in_3d=False) .
I did 3d separation. Could you check it, please? May be you could add it into blender.
Here is my modification: import bpyimport bpy_extrasimport bpy_extras.mesh_utilsimport bmesh - Pastebin.com
- Open Blender
- Create a plane with UVs
- Go to EditMode and duplicate some faces.
- Run my script and check Console
You will see that my modification will have many UV Shells when the default one will have only one UV Shell.
