is it possible to use cycles without building a BVH or any other type of acceleration structure? I’m trying to prove some theoretical analysis on ray traversal performance.
Found a line (116) in cycles/bvh/bvh_params.h
/* fixed parameters */
enum { MAX_DEPTH = 64, MAX_SPATIAL_DEPTH = 48, NUM_SPATIAL_BINS = 32 };
Is max_depth related to bvh tree branch limit? I could then set to 0 or 1 and have quasi linear loop over all objects?
Also a there is a requested_layout when building the bvh and one called ‘none’. Maybe I can force this?
Thank you for any insight!
PS. was looking at cycles X source code found here: bvh_params.h · rB
