I am recently working on a project in which I want to render images with cycles standalone. Therefore I am using the C++ API. Sun lights, point lights, spot lights and area lights seem to work fine. But with the lighting of environment maps I get no sharp shadows. Objects throw a diffuse shadow on the ground. However some objects should also cast a shadow on themselves, which is not visible.
I tried the same setup in blender to exclude that the reason is the used hdr file. But in Blender (with using cycles) I get this shadows on the objects. Other things I tried is experimenting with the strength and using different hdr/exr maps but without success.
I tried out different color spaces (“Linear”, “raw”, “sRGB”, u_colorspace_raw, u_colorspace_srgb) but it did not change the shadows in this case although the light looked different. To try out the importance sampling I set the volume_samling_method of the shader to “VOLUME_SAMPLING_MULTIPLE_IMPORTANCE” but that did not have an effect either. I don’t know if this is the correct way to enable importance sampling.
Another thing I tried was to set different update tags (LightManager::UPDATE_ALL, ShaderManager::UPDATE_ALL) - no improvement.
i meant this here: https://docs.blender.org/manual/en/2.80/render/cycles/world_settings.html#settings
This is always needed to sample localized high values like a sun, otherwise the sampler just overlooks the pixels, or sometimes samples them by chance, resulting in fireflies
Actutally it still is present in blender - world > settings > surface > Sampling
In Blender I found that option too. Unfortunately I coudn’t find it in Cycles Standalone even after several hours of searching. I only found the option to choose “volume sampling multiple importance” like I described before.
Maybe have a look at the nishita sky texture commits/code - i remember specifically some slowdowns in realtime sun adjustments due to the importance map being rebuilt… its even outputted to the render status bar - importance map rebuilding or something… should make it easier to track down
This works in Cycles by adding a light with type background. Generally if you want to figure out how something in Blender maps to Cycles, look at the code that does the conversion. It’s in BlenderSync::sync_background_light in this case.
Thanks a lot to both of you! It works now
The solution was the combination of your tips: Adding the environment map with a background light and enabling multiple importance sampling.
And thanks for your tip with looking at BlenderSync, brecht! I already searched in the Blender code but did not find this snippet.
Is there a way to do the reverse and allow a blur level to shadows on a background light? I always get sharp shadows on a shadow catcher with a background spherical mapping and a light added as a background light.
