Measure Tool / can't delete measures
Yes same here, I guess that’s a bug. Seems every kind of delete doesn’t update the saved information until you made a move after that. So deleting the center of an angle measurement will reappear too, but if you move the outer point afterwards it gets updated.
Edit: The same is true if you have another measure line left on screen that you can move.
