Hello all!
Being a relatively new Blender user, I noticed, that the tooltips on input node sockets are sometimes less than helpful (“Input value used for unconnected socket.”). I think, the tooltip is a good opportunity to tell a less experienced user a bit more detail about the input socket at hand.
Before running off coding, I would therefore like to check if this is something worthwhile pursuing and if so, where the documenting tooltip text should live, especially for C nodes whose input sockets are defined via struct bNodeSocketTemplate, which is marked ‘deprecated’…
Best regards,
Christian
