…how about this idea for sculpting on a drawing basis ? :
- layout :
…1- 3d panel to view result .
…2- 2d panel divided into two panels :
…ِA- dimension panel .
…B- color panel .
…* dimension panel :
for drawing the outer perimeters of the model on 3 dimensions separately x ,y and z … starting with y and viewing the result directly live on the 3d view … then switch to x and z before moving to the color panel and moving on to the next part of the model.
…* color panel :
sculpting using only colors ranging from blue to red to define depth on the flat 2d color panel … while viewing the result sculpted on the model with dimensions “applied already” in the 3d panel … then back to dimension panel to make another part of the model …
…* notes :
this way we can also draw topology easily for animation purposes and control UV.
we may have the ability to import 2d images drawn in external applications for the dimension and color panels .
we may also draw the internal shapes in dimension panel with a different color and define which surface we are sculpting on in the color panel.
and who knows… we might use it for animation as well .
