The other type of context sensitivity, would be to automatically extrude face, edges or vertices, depending on the selection mode. Many other apps work this way.
Agreed, I have that working in the extrude script, only using one command in the video. I’ve converted alot of Blender’s tools over to work this way
Interesting idea but seems more like a rip/fill feature. I think existing extrude edge makes sense although one problem is that normals of the newly created faces will often be mis matched (some inside, some outside), especially on something more complex.
little offtopic:
I love your materials menu script!
… in the end I only selected that script and I made a custom shortcut for it … if it were better than not appearing in front of the object and cover it when pressing the shortcut would be at the top
I hope you will continue to improve it, perhaps offering the ability to change materials and add textures and so on …
@HEAVYPOLY Would be possible with your script to implement (for the “nothing select” part) for it to extrude all (depending on the mode ofc, if it’s faces mode then extrude all faces, if it’s edges, extrude all edges etc…) instead of draw a vert?
I appreciate your post information. Your sharing video was so informative for me. But can I convert youtube to mp3 then it will be helpful for me? Because I always access youtube videos and so addicted.
